Old 12-13-2005, 09:31 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Painless wireing questions....
I have installed a 18 curcuit 67-72 p/n#10206 painless harness in my blazer and have a few questions for those who have installed these kits..
Where did you hook up the gear indicator light and the heater controll light??
All the acc port on the fuse box are hot all the time is that correct or do I have something hooked up wrong???
Any help would be great...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-13-2005, 09:48 PM   #2
68 short step
Re: Painless wireing questions....
not much help here, but how does it pass through the firewall? is it a bulkhead connection or just wires going through a grommet? and bout how much did that cost?
68 short step is offline   Reply With Quote
Old 12-13-2005, 10:00 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
The wires pass through a bulk head but it is larger than the stock one so cutting is required and the stock taillight harness hole is not used so you have to fill it in with a rubber groument.. Cannot remember price right off the top of my head got it at summit racing though..
MEMBER #6377
Project "7DEUCE"
Old 12-13-2005, 11:08 PM   #4
BubbaGreen
tie into the dash lights....that way they will only be on when the lights are on.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 12-13-2005, 11:32 PM   #5
raidermanny
raidermanny's Avatar
Thats how I wired mine too.
raidermanny is offline   Reply With Quote
Old 12-14-2005, 01:40 AM   #6
jhow66
jhow66's Avatar
Only things that should be hot with switch off are -brake lights-headlight switch- hazzard lights-dome circuit. Check large pink wire to ing. switch (this wire feeds fuse panel). It should not be hot at ing. switch with switch off. Back side of switch will have Acc. post on it.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Thread Tools
Display Modes
