Old 07-13-2002, 08:28 AM   #1
chevyman 68 C/10
chevyman 68 C/10's Avatar
original or poly?
I have great bushings in the front of my 69 but when I lower it I was wondering if poly would be any better than the greaseable ones. I am planning on using 87 drop spindles and need to change the ball joints to make it work. If there is no advantage to poly over stock ones in good shape I will just put that money some where else.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 07-13-2002, 01:02 PM   #2
Cyco Path
It seems I've been told in the past, the poly has a longer life and is less likely to squeak.
I'm told they are worth the extra expense.
Looking for '67 to replace the '68 I sold.
Robertsdale, AL
Cyco Path is offline   Reply With Quote
Old 07-13-2002, 01:10 PM   #3
68 with 350 TPI
68 with 350 TPI's Avatar
Polly help cut down on flex and body roll so I think they are worth the extra $.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-13-2002, 01:49 PM   #4
jones
it's been my experience that the poly do last longer but the rubber ones are much more quiet.
69 C15
86 K20
jones is offline   Reply With Quote
Old 07-13-2002, 03:49 PM   #5
slam33
slam33's Avatar
Got all polys on the rear and no squeks, works great
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 07-13-2002, 05:14 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Poly will last almost forever. It is unaffected by oil and road grime...to include salt. I wouldn't even think of getting rubber, onless it was a 100% restoration.
Old 07-13-2002, 08:15 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Poly should come with lube.If not get some for it.All the info I have found says the poly will stay quite and last forever if you lube it well.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-14-2002, 09:32 AM   #8
chevyman 68 C/10
Sorry guys I don't think I made myself very clear. I have the original front control arm bushings that have no rubber in them and are greaseable. I can eliminate them by going to the 87 control arms and putting in poly bushings.
The present bushings do not need replacing,I would have to only change the lower ball joint to make my 87 drop spindles work.
Do I replace the original control arms with the 87 and poly bushings or replace the ball joint and keep the metal greaseable bushings.
How do steel bushings compare with the poly for sway, etc.
Old 07-14-2002, 10:30 AM   #9
slam33
slam33's Avatar
If the bushings are new, wether there metal, poly or rubber, your not going to see any give in them enough to cause any sway. It's only when the worn out that you get that condition. Rubber and poly bushings will give you a little more cushion and won't transmit road noise as mush. If all you need to do is a ball jiont then go with it and pocket the money and time of converting over.
</A>
Old 07-14-2002, 10:35 AM   #10
Low69CST
I would have to think the steel bushings that comein our trucks would offer much less than rubber or polly. I don't think the newer control arms will just bolt on to your cross memember You'd probably have to get the cross memeber and all. You can get disc spindles that will fit directly on your 69 ball joints and tie rods, cutting down expense and work. If all your joints are good i'd do that.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-14-2002, 08:55 PM   #11
chevyman 68 C/10
Thanks guys, I think I will go with the metal bushings and just buy ball joints. low69cst I have the whole shooting match from the 87 already blasted and primed and the drop spindles are Belltech from another 87. All I have to change to make it work is the lower ball joint to use the 87 spindle, I retain my control arms but use caliper and rotor from the 87.
THANKS AGAIN GUYS!!!!!
Chevyman 68 C/10
Thread Tools
Display Modes
