Old 12-13-2005, 11:13 PM   #1
sr67chevyfleet
Question Disc Brakes?
I have the manual brakes on my 67 fleetside c10 I was woundering what it would cost me to put them on the front and maybe the back.If anyone has any imput of the sort I will say thanks now Also is it easy and where can I get them thanks for everthing
steve
sr67chevyfleet is offline   Reply With Quote
Old 12-13-2005, 11:26 PM   #2
68haywagon
I'm watching you!
Re: Disc Brakes?
All depends if you just junkyard a setup, buy a 71 or 72 crossmember/frame, or buy a kit.
I bought a 71 frame and am rebuilding the front crossmember for my 68. All together it will probably cost me as much as a kit, but I also got a 12bolt posi, frame, and a trailing arm.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 12-13-2005, 11:33 PM   #3
sr67chevyfleet
Re: Disc Brakes?
yeah a kit is pretty expensive at least where im looking it like $8-1200.00 I really dont want to pasy that now as far as junk yards go there isnt much around here.
Old 12-13-2005, 11:47 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: Disc Brakes?
You can use the front crossmember out from under a 73-87, lot easier to find and cheaper to replace parts on.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-14-2005, 12:38 AM   #5
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
Re: Disc Brakes?
I think that's what the kits are based on...allows for a wider range of replacement parts.
If you do upgrade use all the parts from the donor ie tie rod, a-arms, and associated ball joints...the works.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 12-14-2005, 02:49 AM   #6
CG
BlahBlahBlah
Re: Disc Brakes?
no kit needed. unbolt entire crossmember and suspension assy out of 71 to 83 bolt it in place of yours. i think i read somewhere you may have to elongate a couple of holes. gives you the disks you want and probably power steering. i had a 67 frame that this was done to...you will probably have to dimple your frame a bit for the steering box also. i bet someone has pictures they can post for ya.
Old 12-14-2005, 08:06 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Disc Brakes?
It's actually 71-87 trucks, and 71-91 Suburbans that can be donors.
Thread Tools
Display Modes
