Old 12-14-2005, 07:42 AM   #1
Buckman
How to install indicator pointer?
How do you install the indicator pointer with tilt on a 71 gmc? Mine is broken off.
Buckman is offline   Reply With Quote
Old 12-14-2005, 09:42 AM   #2
Huck
Huck's Avatar
Re: How to install indicator pointer?
If part of the old piece is still stuck inside the column housing---you got to get that out. Unscrew the two phillips screws that hold in the (PRNDL) thingy and remove it. Then get a piece of stiff, thin wire and make a very small hook on the end and try to fish out the old indicator piece. Once out, then --look at how the new one hooks onto the (PRNDL) --it kind of clips over the bottom a bit. Now just reinstall. The white indicator is supposed to slide in and out as you tilt the wheel housing so some WD40 might help. These things get brittle over time so you might whant to consider this by having a spare. Huck
Huck is offline   Reply With Quote
Old 12-14-2005, 10:02 AM   #3
JimKshortstep4x4
With the tilt all the way down and the indicator housing removed, the old indicator pointer can be removed as it just slides out. Slide the new indicator pointer into the bezel and make sure that it will move in and out freely. once it is in place hook the lower part of the indicator pointer onto the housing and reattach the housing.
Here is a pic that shows the indicator pointer and housing.
Jim
Old 12-14-2005, 12:49 PM   #4
Solver
Solver's Avatar
Huck is right about the old piece probably still being in there. Most I have done had a small piece still left down inside the channel. If you can't fish it out take a lenght of small guage wire - heat it red hot with propane torch- gently insert it into the plastic as far as it will melt in - let cool - then pull the whole works out. had to do this a few times after getting frustrated not being able to hook an edge.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 12-14-2005, 05:04 PM   #5
Buckman
Thanks alot guys. I was afraid that I was going to half to take off the wheel.
Thread Tools
Display Modes
