07-13-2002, 01:07 PM | #1 |
Help mounting armrests please
I got two armrests out of a donor truck and want to mount them in my 67 which never had armrests (Basic metal skins). The mounting bracket in the door has two square holes which a clip or something fits into to screw into. I spent the afternoon at the local auto parts store looking for something that fills that hole like a clipped nut and nothing seems to work, also they have a lot of plastic parts but for this armrest, a metal part would be better. Could someone please look to see what fills the two square holes. I have nothing to compare to and the donor truck is gone. Thanks
Dave
Dave Benamati Hughesville, PA USA |
07-13-2002, 01:36 PM | #2 |
WHYBYNU when old will do
I'm pretty sure its a clip nut that fill the hole. I would go to a hardware store and tell them what you are looking for they migt have what you need. Just my .02. Good luck and let us know what you find.......
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
07-13-2002, 01:48 PM | #3 |
maybe that on of those plastic license plate mounting things would fit.
otherwise you could have a 1/4 in nut tack welded on. good luck J
69 C15 86 K20 |
07-13-2002, 02:41 PM | #4 |
Best bet is to hit the boneyard and look for some doors. Scavenge the hell out of any doors for panel screws, clips, etc. I recently had to hacksaw the armrest off my driver's door, those screws were fused into the nuts.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
07-13-2002, 02:47 PM | #5 |
They are called a cage nut. If you can not find anything I carry them new. They are .40 cents each. Thanks Bill
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
07-13-2002, 02:56 PM | #6 |
What I did then I added arm rests to 69 was use the grove nuts from the door handle control unit, I had replaced the units with new ones. The nuts are the same. You have to punch them out of the unit and snap them into the door
1969 GMC S/B S/S 3" drop |
07-13-2002, 09:30 PM | #7 |
Thanks...I found a solution
I went to the local Wal-mart tonight to pick up diapers for my kid and walked by those license plate mounting plugs (thanks Jones) and figured for $1.69, it's worth a try. I came home, tapped them in with a hammer and screwed the armrests in, worked like a champ. Thanks again!
Dave
07-13-2002, 09:59 PM | #8 |
GYRO GEARLOOSE
Probably will work good until you really tug on the armrest. Lowes used to have all that stuff until they sold out in the past couple of months. No more bins full of goodies.
07-15-2002, 09:47 AM | #9 |
Keepin' It Stock
Think you looking for the arm rest retainer nut. It's a plastic square nut for attaching arm rest to door. Chevy Duty at http://www.chevyduty.com/ sells them for $.49ea - part number 19-692
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
07-15-2002, 12:10 PM | #10 |
Back in the sticks
Are those nuts the same for the door panel screws too? If so I know I need some new ones. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
07-15-2002, 02:21 PM | #11 |
Now the others dig........
do they really just pop right out??? I need to try that....I thought they were welded in......
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
Thread Tools | |
Display Modes | |
