Old 12-20-2005, 08:41 PM   #1
smackmatic
smackmatic's Avatar
Protect-O-Plate
Does anyone know if there is a way to decode the protecto plate? I was unable to find anythjing online.
Thanks.
smackmatic is offline   Reply With Quote
Old 12-20-2005, 10:30 PM   #2
68haywagon
I'm watching you!
Re: Protect-O-Plate
Do you mean the option sheet in the glove box?
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 12-20-2005, 10:46 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Protect-O-Plate
Protecto plate only has the vin and the original owner's info
Old 12-20-2005, 10:56 PM   #4
68haywagon
I'm watching you!
Re: Protect-O-Plate
This is a protect-o-plate
Mike
Old 12-20-2005, 11:10 PM   #5
krue
Designated A-hole!
krue's Avatar
Re: Protect-O-Plate
Post your VIN and some of the knowledgeable guys will help. (If you don't want YOUR vin on here just x out the last four or five numbers).
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-20-2005, 11:38 PM   #6
roger0080
Re: Protect-O-Plate
Try my reply here:
http://67-72chevytrucks.com/vboard/s...d.php?t=164544
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 12-21-2005, 12:02 AM   #7
Longhorn Man
Re: Protect-O-Plate
Roger...do you have a protecto plate that shows any of that info?
If so, you are the ONLY one who does.
Old 12-21-2005, 01:50 AM   #8
roger0080
Re: Protect-O-Plate
I have 3 protect-o-plates: 1969 Chev, 1970 Chev, 1972 GMC.
I have literature concerning 1968 & 1969 Cars and Trucks Protect-o-Plates (dumb luck as it may be).
Fortunately I see have both a plate and the literature for 1969.
Surprisingly it looks like the literature matches what's on the plate. Wow.
From this 1969 Chev protect-o-plate and literature I can see:
- VIN Number (duh)
- Carburator Code "R" = Rochester
- Engine Number "V0325U5"
- Rear Axle Number "JQO318K"
- Vehicle Build Month Code "3" = March 1969
- Transmission Number "N9S16"
- Chevrolet Trade Mark.
1968 is very similar except that they had the last two digits of the paint code on there also (since all paint codes started with "5" ) or else an "SP" if it was special paint.
This '69 plate came out of a Junkyard many years ago so I can't go back and look for these numbers on the truck.
These 3 plates all have 6 fields of info in about the same place on the plates so I presume it is safe to assume that the field locations mean the same for the 1972 one (?)
You may have tried it but Google on 'protect-o-plate decode' and you will get a lot of info for cars, but I haven't hit on anything about pickups and trucks. Bummer.
HTH.
-Roger
Old 12-21-2005, 02:00 AM   #9
roger0080
Re: Protect-O-Plate
Now looking more closely the picture posted by 68haywagon, that protect-o-plate looks just like the '69 plate I have *except* that those 2 digits in the top right corner of the picture should be the last 2 digits of his paint code found on the SPID sticker in the RPO column.
If his signature is correct saying he has a 1968 Longbed in "white" then the paint color for a 1968 White is "521". The embossed two digits in the upper right hand corner looks possibly like "21" too me, but it is not real clear in the picture. Which would then match what the literature says.
-Roger
P.S. I see the hand written date on the warranty card below the plate in the photograph is 1968 so I assume that his picture and truck all match.
Old 12-21-2005, 09:11 AM   #10
68haywagon
I'm watching you!
Re: Protect-O-Plate
Yes that is the original plate to my truck, I found that and a few other things in the glove box the day I brought it home. This is what is on my protect-o-plate:
.......26..........CS148T119313.....R
F0201PF.........HA0126K.............1
M8A18...................................(Chevy emblem)
There is a sideways chevy emblem where it says (chevy emblem) under the 1. The paint code is "4526AA Off-White" in the glove box.
I don't know what any of those numbers/letters mean, I haven't researched it yet.
Mike
EDIT: it wouldn't space out right so I put those periods in to make it look right, the periods are not actually there.
Old 12-21-2005, 09:47 AM   #11
Leonard1
Leonard1's Avatar
Re: Protect-O-Plate
Check this out:
http://www.camaros.org/numbers.shtml#POPCodes
Yeah, I know the information is for Camaros, but it is basically the same for any Chevrolet from the era. I have a few POP's out in the shop, and can dig them out if needed. Also, see here:
http://www.gmcpaulstruckparts.com/67-72_chevy.htm
for more decoding.
Haywagon's decodes as:
26 - paint code
CS148T119313 - VIN
R - Carb code, Rochester
F0201PF - Engine assembly date code, should match the suffix code stamped on the front pad of the engine, assembled Feb. 1 (1968) at Flint, 250ci six cylinder.
HA0126K - Rear axle code, should match the stamp on the front of the passenger axle tube, 3.73 ratio, assembled Jan. 26 (1968).
1 - Accessory code, I'm not sure what this designates for a truck.
M8A18 - Transmission assembly code, should match the date code stamped on the transmission. I don't know what "M" designates, but it is a 1968 transmission, assembled January 18 (1968).
edit: It is true that the owner's name wasn't stamped into the plate, since the plate was made at the factory, but it was embossed on tape and affixed to the plate at the dealer.
Roger, I also have a POP with "U5" at the engine suffix. I assumed that this was a mistake, and that someone put the wrong stamp in the gang that day, but maybe it was intentional. Was the truck built at the St. Louis plant?
Leonard1 is offline   Reply With Quote
Old 12-21-2005, 10:06 AM   #12
smackmatic
smackmatic's Avatar
Re: Protect-O-Plate
I will have to post the numbers tonight when I get home. I just want to know what transmission and rear the truck had in it new. The engine is the original from 1967!
Old 12-21-2005, 06:25 PM   #13
roger0080
Re: Protect-O-Plate
Leonard, it was built at Tarrytown of all places.
"1" in his example is the build month. "1" = January 1968.
Aug '67 = 8
Oct '67 = O
Nov '67 = N
Dec '67 = D
Jan '68 = 1
Feb '68 = 2
... sequence ends at July '68 and starts over for production year 1969...
Jul '68 = 7
Aug '69 = 8
Thanks Leonard, I think between the two of us we nailed this topic. I believe I don't have the axle/trans/engine decode codes to break the numbers down more - thanks, was wondering about them...
-Roger
Old 12-21-2005, 10:09 PM   #14
smackmatic
smackmatic's Avatar
Re: Protect-O-Plate
ok, here are the numbers off the plate.
F1213TA engine, I know this one because it is on the block
HA1213W....Trans?
M7510.........Rear?
So, if anyone can figure them out that would be cool.
Old 12-21-2005, 11:01 PM   #15
Leonard1
Leonard1's Avatar
Re: Protect-O-Plate
HA1213W is the rear end code, and will be stamped on the passenger side axle tube, facing forward. HA=3.73 assembled Dec. 13, 1966 W=the manufacturer code.
M7510 is the tranny code, I assume it's a manual three speed? 7=1967 model year The 5 should be a letter and stands for the month of assembly, I haven't ever seen a number in that location, and 10 is the day of the month.
Old 12-21-2005, 11:02 PM   #16
Leonard1
Leonard1's Avatar
Re: Protect-O-Plate
Roger, thanks for the explaination on the build month.
Old 12-22-2005, 10:15 AM   #17
smackmatic
smackmatic's Avatar
Re: Protect-O-Plate
Sorry, thats M7S10
It is a manual 3speed. I see 3 differrent manual 3 speeds listed in the owners manual, does the M indicate which one it is?
thanks for the help.
Old 06-03-2013, 07:11 PM   #18
ItMightScrape
ItMightScrape's Avatar
Re: Protect-O-Plate
My protect-o-plate reads:
03 CE247Z12xxxx R
V1209YH JS1129G Z
T329T
I cant seem to find all the info online so any help would be greatly appreciated!
ItMightScrape is offline   Reply With Quote
Old 05-19-2014, 06:02 PM   #19
bruceman1968
bruceman1968's Avatar
Re: Protect-O-Plate
ItMightScrape, Well it's been a year since you asked this question, but I see your still active, so here goes. I've been researching the P-O-Ps for our trucks lately, and that's how I came across this thread. From what I've learned so far, this should do ya.
03 = 503 light green paint exterior
CE247Z12xxxx = VIN Number
C = 2wd
E = V-8
2 = 3/4 Ton
4 = pickup Cab & Bed
7 = 1967
Z = Freemont Assy Plant
12xxxx Build Sequence number Starts at 100001, so yours is number 2xxxx built
R = Rochester Carburetor
V1209YH = Engine Number
V = Flint
12 = December
09 = 9th day
YH = 1967 327cid 220 hp
JS1129G = Rear Axle Code
JS = C20 with 327cid, gear ratio 4.57
11 = November
29 = 29th day
G = Detroit Gear and axle
Z = Build Month, December
T328T = Transmission code
T = Powerglide
329 = Julian date, November 25th
T = Truck
Under the Z you should have a Chevy trademark. It's a bowtie turned on it's side, it just means Chevrolet.
bruceman1968 is offline   Reply With Quote
Old 11-12-2020, 11:04 PM   #20
cypressbog
Go Pack Go!
Re: Protect-O-Plate
I needed to bring this up to the top because a heavily heated discussion on a FB group. I always was under the impression that there’s no such thing as a numbers matching truck. Not like numbers matching for a Vette or early Chevelle.
My question to the experts is:
Can a protecto-plate and build sheet be used to document a truck as numbers matching? It looks like they can?
cypressbog is offline   Reply With Quote
Thread Tools
Display Modes
