01-01-2006, 02:57 PM | #1 |
Battery drain
I got a new battery and now I have a draining problem. I am not good with electrical systems, but how can I locate the problem?
GMFamlee 1971 Cheyenne 20 LWB 400BB 1996 GMC Sierra SL SWB 4X4 ExtCab 2001 Honda Civic EX (Mamma's Ride) "He stops talking only long enough to switch feet" |
01-01-2006, 04:54 PM | #2 |
Back in the sticks
Re: Battery drain
Remove the fuses one at a time until the drain stops. If that doesn't isolate it, you'll have to start checking the hot wired equipment, like headlights, stop lights, hazard flashers. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
01-01-2006, 05:42 PM | #3 |
member #16
Re: Battery drain
The easiest way is to unhook the neg. batt cable and connect one end of a test light to the cable and other end to terminal. It will light up if there is a draw, and go out when you find it. Dont forget the glove box light if you have one and the alternator after checking fuses. Good luck John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-01-2006, 06:52 PM | #4 |
Re: Battery drain
check your alternator mine was bad killing the battery when the truck was off if you still got an externtor voltage reg i'd recomend switching over to an internator volt reg i got mine off an 83 chevy k-10 4x4 its an Palladium ALTERNATOR PREMIUM Part Number: P7127M3 from advance auto lifetime free replacement 38.88 anyway heres the link to the converstion if you end up with an bad alt. http://67-72chevytrucks.com/vboard/s...d.php?t=119379
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-02-2006, 12:27 PM | #5 |
Re: Battery drain
Thanks, folks. I knew I had my work cut out for me. I hate electrical problems...
Thread Tools | |
Display Modes | |
