Old 01-08-2006, 07:10 PM   #1
Inthuwind
Straight jacket required
Inthuwind's Avatar
Caddy brake help!!!!!
Will '85 Caddy Eldorado Barritz rear discs,rotors,calipers and backing plates work on a '72 axle??? H E L P!!!!!
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 01-08-2006, 08:41 PM   #2
Inthuwind
Inthuwind's Avatar
Re: Caddy brake help!!!!!
Anyone???
Old 01-08-2006, 09:10 PM   #3
FormerMember
Not sure the bolt patterns are the same.
Thought it was independent rear suspension.
I know you can weld though:
brackets can be found at www.loufegersracing.com they're 12.00 each if your caddy ones don't work.
Rotors can be sourced from a 94-96 Impala with the 9C1 option disk brakes new from autozone if your caddy ones don't work.
Run the caddy caliper for the ebrake function. Be sure to use it regularly or it will suck.
FormerMember is offline   Reply With Quote
Old 01-08-2006, 09:51 PM   #4
john
member #16
john's Avatar
Heres some info. John
john is offline   Reply With Quote
Old 01-08-2006, 10:01 PM   #5
neonlarry
neonlarry's Avatar
I'm not sure on the 85's, I know 76-78 Calipers work and they have an e-brake. But the rest will not work you will need custom caliper brackets and custom (as in redrilled) rotors. There is also a link somewhere around here to a place that makes the e-brake cable.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-08-2006, 10:21 PM   #6
Inthuwind
Inthuwind's Avatar
Thanks so much for the info. I'm leaning more to Caprice 9C1 setup. I saw the Caddy in a junkyard and thought it might be feasible. I think the Caprice would be a better choice, although I might have to buy all new stuff. Once again, thanks for the help!!!!
Old 01-08-2006, 10:28 PM   #7
FormerMember
The only issue is getting the backing plate that the caliper bracket bolts to. It houses the ebrake. It's also not made by GM anymore.
Old 01-08-2006, 10:35 PM   #8
Inthuwind
Inthuwind's Avatar
If I found the Caprice in a junkyard, could I just pull the backing plate off it as well?
Old 01-08-2006, 10:44 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
I hear about guys using rear brakes from a Ford Explorer. the parking brake is a drum set-up inside the rotor with the cable running through the backing plate. I think you would have to re-drill the rotors for our bolt pattern though. just an idea
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 01-09-2006, 07:50 AM   #10
FormerMember
If it works, sure.
Thread Tools
Display Modes
