Old 01-09-2006, 02:27 AM   #1
JRB
JRB's Avatar
Lower A-Arms 3/4 Ton
Is there any difference between the 68 and 69 3/4 Ton Lower A-Arms? I am doing a Disc Brake conversion. I read that I needed 68's but was wondering if the 69's would work?
Thanks,
JRB
56 Chevy 3100 BIGWINDOW Shortbed Stepside
60 Chevy Apachee 10 Parts Truck
63 Chevy C10 Shortwide
64 Chevy C10 Shortwide
69 Chevy C10 Shortbed Stepside
04 Chevy 2500HD QuadCab 4*4 Shortbed
02 Acura 3.2 TL Type-S (Wife's Car)
JRB is offline   Reply With Quote
Old 01-09-2006, 09:44 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Lower A-Arms 3/4 Ton
The 67-70 arms are the same.....71-up went to the disc brakes, & the steering stop is different. This is not a big problem,you can use the older arms,& just grind the steering stops to get the proper turning radius. best of luck...... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-09-2006, 12:02 PM   #3
JRB
JRB's Avatar
Thanks for the info Longhorn.
JRB
Thread Tools
Display Modes
