Old 01-11-2006, 06:49 PM   #1
ktlx1
Question Door Seal Help Please
All, I put new door seals in on my 70 chevy cab. The particular seals I installed have a hard rubber corner where the top of the door meets the front side of the door above the vent window. This is causing tremendous pressure and wont allow the door to shut easy. Do I have defective seals or is that supposed to be there. Please help the door lock no longer work and you have to slam the door for it to catch.
ktlx1 is offline   Reply With Quote
Old 01-11-2006, 09:05 PM   #2
Green Machine
Green Machine's Avatar
Re: Door Seal Help Please
The sets I have used (3 so far) have what seems to be something inserted into the hollow part of the weather strip at the joint in that corner where it must be spliced. I don't think the originals had that in there either. They will loosen up after a while, especially in hot weather, but it's not to hot here now. Maybe the doors need som adjustment ??
Maybe all the repros are made that way, I don't know, but someone else may know.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-12-2006, 11:11 PM   #3
ktlx1
Gets pretty hot here in Charlotte, thanks for the tip, I openned the weather stripping and took out the insert. Doors close much better. Next project new door latches and strike plates
Old 01-13-2006, 12:02 AM   #4
72MARIO
72MARIO's Avatar
Silicone spray also helps the seals to slide rather than bind when th edoor shuts. GM uses a similar silicone produts on there cars and trucks from the factory.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Thread Tools
Display Modes
