01-17-2006, 07:48 PM | #1 |
Mickey Thompson DR's
I'm considering getting American Racing 23 series wheels in a 15x10 and mounting the Mickey Thompson 325-50-15 drag radial (not ET street).
Anyone have this combo or just any 15x10 wheel with these tires? If so how do they perform and if you have pictures...please. Thanks.
86 C-10 SWB 2wd -355/TH350, 3:73's (Vin# says its a V6) Best ET: 13.0 @ 101mph (NA) 11.9 @ 108mph (100 shot) 02 Chevy 2500HD DMax (tow vehicle) 84 GMC Sierra 2500 00 Formula M6 hardtop |
01-18-2006, 12:10 PM | #2 |
Re: Mickey Thompson DR's
I run a set of 315-60's on 10 inch wide centerline autodrags. They work as good as the slicks I had before and are cheaper. I have run 11.94@112 with a 1.66 60ft. with these with 15psi air pressure. If you run them on the street air them up to spec and they're like any other radial tire. Traction suffers with them like this though. This pic from Brainerd shows that the sidewalls even wrinkle. The pic sux because of the massive resize to post it.
85 GMC 1/2 ton LWB 4150lbs. 383 SBC with Twin MPT70 Turbos 850 CSU carb TH375 3.70 gears Ultimate 10" Converter 10.11@136.6 with 1.64 60ft. on 10.5-31-15W |
01-18-2006, 12:57 PM | #3 | |
01-18-2006, 01:18 PM | #4 | |
Insert Witty Text Here
Slonaker |
01-18-2006, 03:17 PM | #5 | |
01-18-2006, 03:29 PM | #6 |
What engine and transmission do you have in that truck to make it run like that? I wish my '72 Nova ran that fast, but i dont have the money to go fast.
01-18-2006, 07:15 PM | #7 |
Hey maybe you guys can help me also on the same subject. I have an '86 sb 2wd with a 383 stroker. (Sportsman II heads (64cc) flat top pistons comp 286h cam holley 750VS............ any how it has a 2500 stall with a 3.73 gear with a powertrax no slip posi unit. It wont hook up for nothing w/ street tires so I was thinking of buying a set of the MT ET street radial tires. The truck has stock suspension other than being lowered 2" in the rear. Do you think these tires would help me out any or would it still break loose or wheel hop just as bad? If I run it now it I have to rolllll into the gas to keep it from spinning.
PS I guess I need to change my signature as my "bad 383" is running strong. I'm guessing it has about 390-400hp at the flywheel. Thanks Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week. Last edited by red86chevy; 01-18-2006 at 07:16 PM. |
01-18-2006, 07:47 PM | #8 | |
01-19-2006, 06:24 PM | #9 | |
Do you by chance have a stationary picture of it to compare the amount of rise to ?
Born and proudly residing in a Red State ! Last edited by f.monroe; 01-19-2006 at 06:26 PM. |
01-19-2006, 08:30 PM | #10 |
Thanks for the info and picture BADGMC. That's a helluva nice sleeper truck there!
I ordered the wheels yesterday. I'll pick up the tires tomorrow and post some pictures when they're installed.
01-20-2006, 02:00 AM | #11 | |
Thread Tools | |
Display Modes | |
