01-17-2006, 09:02 PM | #1 |
Will my headlights be brighter with 14v+ over 12.5v+?
So I went and did all the voltage testing today, on my electrical system..found out a few things. All tests were done at 2000rpm:
Alt Voltage = 14.0 Bat Voltage = 14.0 Junction Block Voltage = 14.0 Fuse Block "Bat" Voltage = 14.0 Headlight Voltage = 12.5...this didn't change going from idle-2000rpm, it stayed right at 12.5. My question is, would my lights be BRIGHTER if I had 14.0v+ at the lights? Or are they putting out 100% at 12.5v+? Thanks! |
01-17-2006, 09:48 PM | #2 |
Real Men Wear Orange
Re: Will my headlights be brighter with 14v+ over 12.5v+?
I think they're at 100% with 12 volts. If anything above does make them brighter, they'll burn out faster because of increased wattage.
01-18-2006, 02:40 AM | #3 |
Until Seventy Times Seven
Like SlapFish posted, you're near the design voltage. I believe most headlamps (square or round) for these trucks are designed to operate at 12.8 volts. Some of the manufacturers of high performance headlamps warn against operating them above 14 volts, otherwise they may shatter. I'm not sure on the standard halogens. So, you're close to operating voltage of optimal brightness.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
01-18-2006, 02:57 AM | #4 |
I believe when I had my 72 SWB I found a resister in the headlight feed to limit voltage and like stated above to prevent bulb burn out. What you should be more concerned with is if voltAGE drops below 12vthen they dim.. hope this helps ........
01-18-2006, 04:11 AM | #5 |
Professional Grade
I've been running my 89's high beams at 14.6 volts for several months now. It makes them nearly twice as bright as they were at the 11 some volts they were at before, and I haven't burnt one out, so I am personally a fan of running relays to hook the lights straight up to the battery.
All newer vehicles are run this way as well -- Voltage straight from the battery straight to the headlights via a relay. Also greatly reduces the amount of higher amperage current you have flowing inside the cab
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-18-2006, 12:52 PM | #6 | |
01-18-2006, 02:07 PM | #7 |
BeWarE tHe eViL CrAnkTOe!
do you have a diagram or pics of how you did this?? sounds like a cool lil upgrade.
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
01-18-2006, 02:22 PM | #8 |
Regular guy
here ya go...
http://www.madelectrical.com/electri...adlights.shtml
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. |
01-18-2006, 03:27 PM | #9 |
K5Camper
There was a large discussion here on adding relays last month. Short version, stock system sucks, adding relays to get direct system voltage will make stock lights brighter. Add H4 conversion bulbs and they will get even brighter over halogens running 14v. Mike was nice enough to take our write up and put it on his site for quick reference:
http://www.73-87.com/7387garage/exte...ight_relay.htm Eliminating the stock built in voltage drop will make your lights brighter.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
01-18-2006, 03:31 PM | #10 | |
01-18-2006, 04:14 PM | #11 |
K5Camper
The LMC kit is cheaper. I think 20-30 bucks. But, it does not include any fuse protection for the power supply to the relays. Add That cost to the LMC kit. The LMC kit is decent even if the instructions suck. But if you don't mind doing it yourself its not hard to put it together.
01-18-2006, 06:09 PM | #12 |
Magnificent bastard
I have the LMC kit on my Suburban. The lights are noticeably brighter, plus I don't have all the headlight current running through the light switch anymore.
The wires on the LMC kit are just barely long enough to hook everything up, my relays are hanging from the core support right next to the battery. Someday when I feel ambitious, I will extend the wires to put everything where I want it to be. Overall, not a bad kit for the price, and the instructions are in "Broken English", which is good for a laugh.
1977 Big Block Burb |
Thread Tools | |
Display Modes | |
