01-18-2006, 05:54 PM | #1 |
Replacing door hinge pins
Sorry if this has been asked before (I searched but did not find anything)....
Does anyone have a procedure or any insight on replacing door hinge pins? I have two trucks that need it. Thanks in advance!
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
01-18-2006, 06:33 PM | #2 |
Re: Replacing door hinge pins
Easy as pie. 1st, take some kind of marker and mark an outline of the hinge on the door. That way, you can put it back in the same place when completed. Next, take 1 hinge off the door at a time, making sure to support the door from falling. Put that hinge in a good vice, and take some kind of steel punch, and beat out the pin. Make sure you clean out the old bushings. Put the new rebuilt hinge back on in reverse order. When I did mine, my pins were fine, just had to replace the bushings. Get bronze ones. Chevy dealers and auto part stores have them. If I remember right, I believe they are 1/2" bushings. Another member on here can verify that or not.....
1997 GMC Sierra Ext 1965 Mustang |
01-19-2006, 01:22 PM | #3 | |
01-19-2006, 03:15 PM | #4 |
Old Skool Club
When Classic Truck magazine did the restomods on the '68 SWB big block pickup , they showed a tip on getting the hinges reinstalled where they came from. They drilled a hole into the body of the hinge, as it mounted on the door , and onto the body. Then, they inserted a drill bit into the hole to realign the hinges exactly where they needed to be.
Now, this will only work if they have not been moved from their original positions and if they are in good shape, even though they need bushings/pins. Gotta be sure the cab isn't tweaked, and so forth. But, I gotta replace mine, too.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-19-2006, 03:58 PM | #5 |
No...you really have to remove the hinge to do this. Those pins can be a bear to beat out. Trying to do that with them on the door would be a trick.....
01-19-2006, 04:50 PM | #6 |
Here's some pictures and an article from Webrodder.
http://www.webrodder.com/article.php?AID=273&SID=27 Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
01-19-2006, 05:01 PM | #7 |
http://www.earlyclassic.com/tech.asp...le%20Rods%20P9
There is a how-to link that was on the early classic website, might be the same thing. Had it saved in my favorites. |
01-20-2006, 09:57 AM | #8 |
Thanks for all the help! The articles are great!
01-21-2006, 11:08 AM | #9 |
Old Skool Club
Man, I'm glad you had that link saved. That's the article that I was referring to. Thanks for posting the link.
Thread Tools | |
Display Modes | |
