Old 01-19-2006, 02:15 AM   #1
53burb
53burb's Avatar
Carb adj.
I was messing with the A/F adjustment earlier. I have an 1806 Edelbrock (same as 1406 with Adjustable Valve Secondaries & 650CFM). If I turn the A/F screws in all the way, there is little or no change in idle at all. This is with both screws turned all the way in. I adjusted the floats, but no change. I yanked out the #1 cylinder spark plug a couple of weeks ago to set the engine at TDC to adjust the valves, and it wasn't fouled or looked like excessive fuel at all. I guess what I am asking is: Do I need a fuel regulator?? BTW it is a 350 with a recently replaced fuel pump...
53burb is offline   Reply With Quote
Old 01-20-2006, 10:32 AM   #2
53burb
53burb's Avatar
Re: Carb adj.
ttt
Old 01-20-2006, 12:12 PM   #3
Solver
Solver's Avatar
Re: Carb adj.
Sounds like a vacuum leak to me . should idle poorly with screws all the way in. try spraying some carb cleaner around the base of carb while truck is running and see if the engine speed changes. if the speed changes you have found your leak
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 01-20-2006, 04:32 PM   #4
53burb
53burb's Avatar
Re: Carb adj.
Thanks, I will try it this weekend. Anybody else have anything???
Old 01-20-2006, 04:35 PM   #5
Sonny's at Work
Re: Carb adj.
WD-40 is a little safer....
Sonny's at Work is offline   Reply With Quote
Old 01-20-2006, 05:26 PM   #6
MrC1
Dork For Days
MrC1's Avatar
Lightbulb Re: Carb adj.
You didn't mention if this was a typical truck engine or if you've cammed it up. By chance you've got a big cam and a fairly wild idle, it's possible that you'll have to revert to the old "drill a hole in the throttle plates" trick. This allows the engine to have enough air to idle correctly while not opening the throttle blades too much, which bypasses the idle circuit.
If you've got a mild engine, just ignore everything I just said, er typed.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 01-20-2006, 06:23 PM   #7
53burb
53burb's Avatar
Re: Carb adj.
The engine has a 268 Competition Cam in it. I don't know all the specs on it other than it has .454 lift on intake & exhaust on it, Edelbrock Performer 2101 manifold, HEI, & dual ramhorn exhaust with glasspacks. It idles fine, only the idle doesn't change when both screws are turned all the way in.
Thread Tools
Display Modes
