01-19-2006, 07:47 PM | #1 |
*PIMP*
rear end ????? feedback asap
does it matter what time of rear suspension your rear end came out of???
here's the senario... 67 with coils wants to put a 71 rear end which had leaf springs... will it work???
http://members.cardomain.com/bigstoys |
01-19-2006, 08:38 PM | #2 |
Re: rear end ????? feedback asap
You will need to weld on the bracket for the coils, as the leaf spring brackets are different.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
01-19-2006, 09:32 PM | #3 |
If you are putting the 71 in a 67, maybe you just need to compare the perches and move as necessary. This should be a possible swap. May be easier just to find a 71/72 that came from coils.
01-19-2006, 09:36 PM | #4 |
i don't think the leaf rears had panhard bars so you'd have to weld bracket for that also
01-19-2006, 09:50 PM | #5 |
Swap the internals between the housings?
01-19-2006, 10:16 PM | #6 |
and re-use the 67 6 lug axles? --- should work
01-19-2006, 10:49 PM | #7 |
Why are you doing the swap and what kind of differentials are they? 12 Bolt Chevy? 10 Bolt Chevy? Are you looking to change the ratio?
01-19-2006, 11:10 PM | #8 |
If your looking at swapping internals, like axels, the 72 axle is a bit wider. I think about 3/4". But you should be able to swap out center sections if you just want the gears out of the 72.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-19-2006 at 11:11 PM. |
01-20-2006, 08:34 AM | #9 |
It`s a`71.
01-20-2006, 11:13 AM | #10 |
*PIMP*
the 67 has the disc brake conversion which is now 5 lug and the rear is the factory rear 6 lug. we want to buy rims and what not and it's just easier to buy all the same lug pattern ie. tire rotation, blow outs. i think the factory rear is a 10 bolt and the new rear is a 12 bolt posi with 3.73's. so we have to cut brackets off of 10 bolt and re weld on 12 bolt.... am i correct.
01-20-2006, 11:14 AM | #11 |
its all about the +6 inches
71...still 3/8 inch wider.
01-20-2006, 11:28 AM | #12 |
OR, you could do what I am planning on doing. I can't seem to find a good coil spring 71/72 rear-end, and I too, have a 5 lug disk brake set up on my truck with a 6 lug rear. Early Classic Enterprises sells 6 lug front rotors that will work on your truck. They are about 180 bucks for the pair plus shipping. Just a suggestion....
The rear ends I have found around here are like $250 and well used. Make sure when you cut/weld the perches that you get the angles correct on them and that they are straight and square. It sucks when you burn through a set of rear tires after only 10K miles
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-20-2006 at 11:29 AM. |
01-20-2006, 11:49 AM | #13 |
2 bills for rotors?!?!
I used to push those for them for the same reason you are bringing them up... but man, 2 hundred bucks. |
01-20-2006, 12:05 PM | #14 |
Andy, that's just what I've seen in their catalog, I think $89 each? If you know where I can get them cheaper I would be much appreciative. I only paid $70 for the pair of 5 lugs I got from Advance Auto.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-20-2006, 01:10 PM | #15 |
I know it differs from junk yard to junk yard, but around here you could get a whole rearend for less than 100 bucks... it's just a matter of waiting untill one comes through...esp if you want a particular gearing.
Have you contacted local machine shops to find out what it'd cost to have your axles redrilled? |
01-20-2006, 01:55 PM | #16 |
The yard's round here must have all gotten together and agreed $250 was the going rate. I went to 4 near columbia (SC) and they all wanted $200-$250. I'm not a big fan of redrilling axles. As far as rims, I'm going with a brand new set of white spokes so 5 or 6 lug won't matter.... I'm going back to Cola this weekend, might be time to check around again.....
Thread Tools | |
Display Modes | |
