-Chris
![]() Join Date: Sep 2002
Bleeding Brake Lines?
What order do I go in to bleed the brake lines? Isnt it the furthest from the master cylinder all the way towards the closest? Any other tips or tricks to get the job done better is welcome, Thanks guys.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
Re: Bleeding Brake Lines?
Everything I have read, says right rear, left rear, right front, left front.
Check www.classicperform.com for more information on brake bleeding, and I think brothers had information on their website also. Check the classic truck mags. websites also.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
its all about the +6 inches
While I will get flamed for saying this... that is way outdated info that doesn't matter anymore.
That rule was made when there was one line coming from the master cylinder...one resivour... back in the old days... older than our trucks. Now (and including these rigs) they have basicly 2 systems in one. The rear brakes and the circuit that feeds it... is all seperate from the front stuff. So if you bleed the front first, the rear is totally unaware of what's going on... and unefected. Everything you read will tell you to do it the way they did it 50 years ago, and some people will stress over it and call you anidiot for not doing it that way.... but it simply doesn't matter anymore. Here's another one... go ahead and set your battery on the cement floor. it won't go dead. You'll be called an idiot for doing it, but it won't go dead. |
You are right about the 2 different systems, my dad drove a 65 gmc around for years with only front brakes in the mid 80's, and that was with the single reservoir m/c.
Speed Bleeders. SO worth the $$.
http://www.speedbleeder.com/ You can find them in the HELP! section of the auto parts store. I have them on my front brakes now, looking to do them on the rear really soon, as well as a full set of them for my Frontier.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Plenty of cars even use a diagonal system where the front right side linked to left rear and vice versa.
I'll get flamed for this, but I bleed most all my brakes by gravity. I have for years too. I don't like the pump and squirt stuff and don't have a pressure bleeder. I work alone, so I simply fill the reservoir and lay under the truck contemplating the meaning of life while the fluid makes it's way down and out the bleeder screw. Then, close it and go to the next wheel. It helps to tap lightly on the metal lines with your bleeder wrench while you're waiting. That tends to break up bubbles and make the fluid flow quicker. Do all 4 wheels, then pump the pedal a few times vigorously, then repeat the bleeding procedure. Works every time, and doesn't usually take over 10 minutes or so.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 01-28-2006 at 08:19 PM. |
Tx.... No flaming here... I do it the same way personally.
Pumping the pedal to pressurize the fluid stirs it all up and causes large bubbles to become millions of small bubbles. |
I am in total agreement with Longhorn Man. I believe starting with 1968, vehicles were required by law to have separate systems between the rear and the front, hence two reservoirs. When I'm bleeding brakes by myself I attach a hose snuggly to a bleeder and drop the other end of the hose into the bottom of a container (usually an empty beer bottle, just happen to have one laying around
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
Post Whore
![]() Join Date: Feb 2000
A made a power brake bleeder for about $10 that sure works great - especially for people like me who usually work alone link to power bleeder
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Thread Tools | |
Display Modes | |
