Old 01-31-2006, 02:38 AM   #1
Canadian72GMC
3/4 ton wheels
Does anyone know if any of the aluminum wheels off of the newer GM trucks will fit my 76 3/4 ton crew?
Canadian72GMC is offline   Reply With Quote
Old 01-31-2006, 03:23 AM   #2
longhorn71
longhorn71's Avatar
Re: 3/4 ton wheels
the wheel bolt pattern is the same.I know the wheel off set tucks the tires in more on a 67-72 truck but not sure on the newer ones
longhorn71 is offline   Reply With Quote
Old 01-31-2006, 07:12 AM   #3
Re: 3/4 ton wheels
Das right.I`ve seen them and they look fine.You`r not going to get a wide stance look out of them.
Old 01-31-2006, 07:16 AM   #4
3qtrtontarrer
Re: 3/4 ton wheels
most 8 lug wheels are the same, just different backspacing. i have new HUMMER WHEELS ON MY 70 3/4
3qtrtontarrer is offline   Reply With Quote
Old 01-31-2006, 12:53 PM   #5
Scrubby
Check out GMTrucks.org
Re: 3/4 ton wheels
I have them on my 71 burb.
You need conversion lug nuts to run the center caps. More info here:
http://www.gmtrucks.org/wiki/faq/8_lug_wheels
Scrubby is offline   Reply With Quote
Old 01-31-2006, 02:03 PM   #6
Eyegore
What Hump?
Eyegore's Avatar
Re: 3/4 ton wheels
My son has the newer ones shown above by scrubby on his 78 camper special
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 02-03-2006, 01:54 PM   #7
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: 3/4 ton wheels
I have the newer wheels on my truck, the only thing you need is to buy the lug nuts to use the center caps.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 02-03-2006, 03:17 PM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: 3/4 ton wheels
I know I probably asked this before but do your tire rub TexasJeff? Did you install new coil springs or anything in the front? Is your truck a heavy (beefier) 3/4?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-03-2006, 10:38 PM   #9
Canadian72GMC
Re: 3/4 ton wheels
thanks for the responses. Where did you get them and what did you pay if you don't mind me asking?
Old 02-07-2006, 09:11 AM   #10
TexasJeff
TexasJeff's Avatar
Re: 3/4 ton wheels
My tires don't rub at all, wheel lock to lock no problems. My truck is a standard 3/4 ton with just over 100,000 miles and the only thing I have done to the front end is put new shocks on it and change out the steering box, other than that it is all stock GM. The tires are LT285-75R16. I got wheels from a tire and wheel shop here in the Houston area, I paid $100 a wheel with the center caps, bought the lug nuts off e-bay for $40 from ez accessories, sorry about the slow response, been busy with work.
TexasJeff
Old 02-07-2006, 07:28 PM   #11
Russell
Professional Grade
Russell's Avatar
Re: 3/4 ton wheels
I've got a set of the steel wheels on my 3/4 ton 4x4 (actually, less the frame and front diff, she is all 1 ton equipped, so its a bit taller than the average 3/4 ton) and they fit real good Just need some bigger meat for her, she has 31s at the moment, but could definitely use a set of 33s
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-08-2006, 03:13 PM   #12
MylilBowTie
Right turn Clyde
Re: 3/4 ton wheels
Those 285-75-16s are 33in tall thats why I was asking. Are the Control arms different for a 3/4 ton and 1 ton?
Old 02-08-2006, 03:49 PM   #13
Russell
Professional Grade
Russell's Avatar
Re: 3/4 ton wheels
My truck is a 4x4, so I'm not sure, but I imagine that 1 ton control arms are different. The frame rails on a 1 ton are different for sure, much beefier.
Thread Tools
Display Modes
