Old 02-07-2006, 04:33 PM   #1
74Chevy74
Question Question about leafspring lengths between LB and SB
I did the short bed conversion on my truck, and I have some questions to see if someone can measure something for me? I know the longbed has longer leaf springs, and now my wheels sit slightly back in the wheel well, so what I am wondering is if the center mark on the long bed springs is different than the short bed? Can someone maybe measure they're short bed from the front leaf eyelet to the center of the rearend? Can anyone chime in on this and tell me if I'm right????
74Chevy74 is offline   Reply With Quote
Old 02-07-2006, 06:02 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Re: Question about leafspring lengths between LB and SB
Shortbeds came with both 52" and 56". My truck came with 56. The difference is 52" springs have the center pin in the center, at 26". 56" springs still have the pin located at 26" from the front but now you have 30" at the back.
I think all long wheel base trucks used 56". Not sure on this but I think I'm right.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-07-2006, 06:10 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The long bed truck have the 56" like Mike said, Short beds had either. The axle shouldn't be any further back than before as the center location is the same. What is the wheelbase length after you shortened it?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-07-2006, 06:39 PM   #4
74Chevy74
Yeah I don't know what is up then? I took out the 14" in front of the leaf springs and took the 5.5" off the back, and when we set the short bed on, the bolts dropped right in so I don't know what the issue can be now? Now I'm hoping it's a problem with the leafs and not something else? I haven't measured the wheelbase yet, what is the best way to do that?
Old 02-07-2006, 07:10 PM   #5
Chevrolet4x4s
Chevrolet4x4s's Avatar
Measure it from the center of the fromt hub to the center of the rear hub.You do not have to remove the wheels just have someone hold the tape measure(or tape it there if you dont have a helper) at the center of the front hub and measure to the center of the rear hub. If you have the correct wheelbase (for a short wheelbase) it should be 117.5 inches
Hope this helps,
Shane
ps tell us what measurment you get.
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 02-07-2006, 07:18 PM   #6
Captkaos
Captkaos's Avatar
Were they perfectly centered before? I think all of them are off a little anyway. Is it forward some? If you cut 14" out of the frame, you should be ok on the wheelbase.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 02-07-2006, 10:40 PM   #7
Chevrolet4x4s
I'll post a pic of my 85 swb in a little bit
Member#20327
Old 02-07-2006, 10:58 PM   #8
Chevrolet4x4s
Hope this helps
Shane
Member#20327
Old 02-07-2006, 11:32 PM   #9
bigblock73
yeller
bigblock73's Avatar
I thought the spring length had more to do with the load carrying capicity (HD = 8 leafs & 56", not HD = 4 leafs & 52") than whether or not is was a swb or lwb truck?
bigblock73 is offline   Reply With Quote
Old 02-08-2006, 03:28 PM   #10
Prerunner1982
Prerunner1982's Avatar
ok.. my 82 has 5 leafs (including overload) and they are 56"
my wifes 87 has 4 leafs (including overload) and they are 52"
BOTH are 1/2ton 2wd longbeds....
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-08-2006, 07:11 PM   #11
swervin ervin
I may be wrong but I think if a SWB came with heavy duty suspenion, it had 6 leafs (5 and 1) and they were 56". At least mine was anyway. I again think if it had standard suspension it would be 4 leafs and 52". Not sure on this though.
Old 02-08-2006, 07:43 PM   #12
bigblock73
yeller
bigblock73's Avatar
Mike, mine has more than 6...
But your married, so I am sure you've been told you were wrong before.
Old 02-08-2006, 08:26 PM   #13
swervin ervin
No, my wife has never told me I was wrong. Yeah, right.
Old 02-08-2006, 09:17 PM   #14
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I will have to recheck but I think my 84 LWB has 52in leafs 3+overload.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-09-2006, 11:50 AM   #15
74Chevy74
Ok I figured out the problem, I guess I failed to mention it was lowered with a flip kit in the rear, and when I fliped the axle it comes with a bracket that the rearend sits one, mine had an offset hole so that is why it's shifted, for some reason I never noticed it with the longbed? But the truck has only been lowered for a month or two and I don't drive it all the time yet? Anyone else done a flip kit and had this problem? I might do another post, maybe they sent the wrong brackets, I'll try and post a picture.
Old 02-09-2006, 04:46 PM   #16
swervin ervin
No, I haven't had this problem but someone else was PM'ing me with this problem. We figured out what was wrong.
They have offset holes on purpose. When you drop it this much and flip the axle you have to shift everything back in order for the driveshaft to work and not bottom out in the tranny.
Glad you figured it out.
Mike
Thread Tools
Display Modes
