02-07-2006, 05:26 PM | #1 |
C10 Club Tennessee
Fuel Sending Unit..Which One?
Pulled my Sending Unit out today and trying to figure out which one to purchase. I have a thread on the parts board about purchasing one I just want to get the right one. My truck is originally a V6 truck but now has a late 70's V8 in it. I wouldn't mind changing to a V8 sending Unit I just want to know what's all involved and I guess I'll decide then whether it's worth it.
Can I get some pros and cons of swapping to the V8 sending unit? By the last pic you can tell what's wrong with mine.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
02-07-2006, 05:31 PM | #2 |
Re: Fuel Sending Unit..Which One?
i need to pay attention to this thread, i need one also.....
02-07-2006, 05:39 PM | #3 |
67-72 Addict!
It probably won't matter if you are not looking for every ounce of performance on your top end. You can buy a piece of steel brake line to attach to the sending unit for a few dollars and bend it (with a tubing bender) to match the old line and replace the rest of the line from the cab to the carb. You have a nice truck and I would personally do it. If you are just cruising around in your truck you won't notice the 5/16 line you currently have.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 02-07-2006 at 05:41 PM. |
02-07-2006, 07:30 PM | #4 |
its all about the +6 inches
If your truck came with a V-6 originally, then it'll already have the 3/8 fuel line.
02-07-2006, 08:16 PM | #5 |
I ordered a V8 sending unit for my son's 68 short stepside. The connector was larger than fuel line. Called the vendor and he said it must have been a 6 cylinder truck, so I ordered the 6 cylinder sending unit and it worked perfectly. While I was waiting I rigged up a reducer between the sending unit and the fuel line going thru the floor of the cab.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
02-07-2006, 09:59 PM | #6 | |
02-07-2006, 11:05 PM | #7 |
C10 Club Tennessee
I have a local vendor about 10 minutes from my house. I called him to see if he had a used one and for how much. Turns out he has a V6 sending unit NEW for $35, so I'm going down in the next couple of days to get it.
Thanks guys, Bryan
02-07-2006, 11:19 PM | #8 |
That is correct,
2 bbl small blocks, and inline trucks have 5/16 fuel line. 4 bbl small blocks, and v-6 have 3/8 fuel line. I do not know about the few 2 bbl big blocks, no clue on them, but I would guess that all big block trucks got 3/8. The only thing I am confused about here... yellow 69 has a chevy... not a GMC. Only GMC trucks had the V-6. What's your vin read? Is it a CExxxxxx, a CSxxxxxxx or a CMxxxxxxx? |
02-08-2006, 03:45 PM | #9 |
C10 Club Tennessee
My VIN is: CS140A135104
02-08-2006, 04:00 PM | #10 |
Active Member
Not wanted to hijack this thread. I have replaced my sender twice yet my fuel gauge doesn't move at all. It just sits at the halfway mark full or empty. When I have the sender out of the tank and move it manually the gauge works fine, however installed in the tank it's a no go... Any thoughts or suggestions?
Thank you, -Fred "The Great State of Florida" |
02-08-2006, 04:41 PM | #11 | |
Check that the tank is grounded, and that the flaot actually floats and not fills up with fuel and sinks. |
02-08-2006, 05:54 PM | #12 |
Your truck came with an inline 6... a 250 or a 292...not a v 6.
02-08-2006, 06:31 PM | #13 |
C10 Club Tennessee
I pretty much meant a 6 cylinder motor of some sort.
02-08-2006, 07:27 PM | #14 |
Go with the V8/V6 one...redo your lines to 3/8. You'll not regret it.
Thread Tools | |
Display Modes | |
