Old 02-07-2006, 11:02 PM   #1
gregfull
gregfull's Avatar
no more prop rod !
Well, finally got all the angles figured out on the gas struts for my hood, and got rid of that ugly wooden prop rod I was using. After the purchase of the hinges and struts, it took about $15.00 and 6 drilled holes to finish the installation.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 02-07-2006, 11:20 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: no more prop rod !
That is SOOOOO NICE
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-07-2006, 11:20 PM   #3
68haywagon
I'm watching you!
Thats a beautiful truck!!
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 02-08-2006, 12:31 AM   #4
Orence1
Orence1's Avatar
Spectacular color combination. A truck to be proud of.
Orence1 is offline   Reply With Quote
Old 02-08-2006, 01:13 AM   #5
taylorde
Just A Tool Hand
taylorde's Avatar
Those hinges are so nice !!!!! And the truck looks good. Glad to see that the shocks worked out for you!!
:hit:
taylorde is offline   Reply With Quote
Old 02-08-2006, 02:16 AM   #6
Russell
Professional Grade
Russell's Avatar
That engine makes me smile
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-08-2006, 05:31 AM   #7
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
So nobody asked yet...whats the part number/where did the shocks come from ? Thank You Sir!
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 02-08-2006, 08:08 AM   #8
70c10
67-72 Addict!
70c10's Avatar
We need more pics!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-08-2006, 08:52 AM   #9
gregfull
gregfull's Avatar
The shocks came with the hinges from www.sachserodshop.com . Thanks for all the compliments.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
09 Suburban
Old 02-08-2006, 09:44 AM   #10
68cajun
68 C/10
68cajun's Avatar
Man that thing sure is sweet!!!!!
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 02-08-2006, 10:47 AM   #11
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
That is SWEET. We do need to see more pics, this truck is so slick.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 02-08-2006, 10:49 AM   #12
ratrod67
ratrod67's Avatar
I feel sorry for the other people you will be competeing against when you start showing that burb.
ratrod67 is offline   Reply With Quote
Old 02-08-2006, 11:09 AM   #13
7deuce
Sold! 2 days after finished
7deuce's Avatar
How did you mount the hinges to the hood. Did you weld a piece to the hood and bolt through the sasche's into that. Any help would be great.
7deuce is offline   Reply With Quote
Old 02-08-2006, 02:04 PM   #14
gregfull
gregfull's Avatar
For those who wanted more pics, here's a thread I started the day I got it home from the body shop.
http://67-72chevytrucks.com/vboard/s...d.php?t=183389
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
09 Suburban
Old 02-08-2006, 05:51 PM   #15
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
That rig makes me happy in the pants. You've truly got a masterpiece. I'd have been pretty scared to start drilling those holes in it. Did you use masking tape so the bit didn't walk on you?
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 02-08-2006, 09:32 PM   #16
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Can we get some measurements of the shock location???? That is a sweet azz set-up seems like the hinges would have come with them struts????
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-08-2006, 09:45 PM   #17
Sweet72
Sweet72's Avatar
Really awesome paint and the hinges/struts make it very unique.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Thread Tools
Display Modes
