Old 02-11-2006, 01:16 PM   #1
speed
Junior Member
speed's Avatar
What are these for?
I'm trying to get some of the wiring sorted out in my 83, have no idea what they are for. Both are on the passenger side by the rear of the valve cover.
Caution LARGE pictures!
http://photobucket.com/albums/c282/i...hevy%20truck/?
Also does anybody have a good wiring diagram for an 83 underhood and dash especially they could email to me?
TIA
Jeff J
86 El Camino
81 Monte Carlo
81 Regal
04 Colorado
speed is offline   Reply With Quote
Old 02-11-2006, 01:42 PM   #2
82c10
needin' money
Re: What are these for?
TIA
they are for a lockup transmsiion, best i can remember, i am betting that the trans in it is not original, and has been replaced with a better one
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 02-11-2006, 02:23 PM   #3
speed
Junior Member
speed's Avatar
The tranny has been swapped out a couple of owners ago, originally a 700r4. Is the part up near the cowl a vacumme switch? There is a piece of hose still on it.
Jeff J
86 El Camino
81 Monte Carlo
81 Regal
04 Colorado
Old 02-11-2006, 03:47 PM   #4
Prerunner1982
Prerunner1982's Avatar
yes it is vac operated, my 82 with th350c has it as well, i am referring to the pic on the right in the link you provided.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-11-2006, 04:38 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
This is the ESC vacuum switch. Here is what it does.
ESC Vacuum Switch
On LE9 engine equipped vehicles with automatic transmission a "tip in" vacuum switch is used. Its function is to provide a momentary contact closure (signal) to the ESC controller during a throttle "tip in" condition which then briefly retards spark timing to minimize knock. The switch contacts are normally open under steady engine vacuum conditions including no vacuum, and all brief increasing vacuum conditions. Basically the switch closes only during rapidly decreasing vacuum conditions such as that encountered on rapid throttle operation.
This is once again, part of the ESC system. Read this article I wrote about it.
http://www.73-87.com/7387garage/drivetrain/escrepl.htm
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-11-2006, 06:07 PM   #6
speed
Junior Member
speed's Avatar
Thanks that explains alot. Since it has had the dist swapped out, I'm going to get rid of the ESC parts & HEI in there and go with a GMPP HEI, Eldelbrock intake and carb.
The wiring under the dash has been hacked up bad so if I can find a good harness to start with, I'll swap that out too.
Jeff J
86 El Camino
81 Monte Carlo
81 Regal
04 Colorado
Thread Tools
Display Modes
