Old 02-17-2006, 02:24 PM   #1
magntik
What years for this radio
I just recently parted out a '68 LWB, the cab and box were pretty much trashed.
But the truck was complete and the interior pretty original.
My question is, I took the AM radio and power lead, my 70 has the DIN size hole cut, so I was thinking of selling this one. Are these hard to come by. worth anything? What years would it be correct for?
Thanks for your help.
If I can figure it out I may be able post pics if needed.
magntik is offline   Reply With Quote
Old 02-17-2006, 03:00 PM   #2
davidh
davidh's Avatar
Re: What years for this radio
I think those radios are going for around $15-40. I have a few. My general thoughts are if the radio hole has been cut then use a din radio but if it has not been cut don't do it. I'm 34 now and I actually listen to the AM radio, talk shows weather and such. Many times I find the origianl AM radio's recption is better than the ones of aftermarket CD players because I don't the manufactures think we will ever use the AM radio, just play CD's and listen to the FM. I live in OK and had an original 83'scottsdale with the AM and I got radio stations in IOWA. I remember flipping out because of this big snow storm they were talking about coming here... then it was that's the Iowa forecast. Kind of funny. Probably good to put in a newer speaker.
davidh is offline   Reply With Quote
Old 02-17-2006, 03:04 PM   #3
davidh
davidh's Avatar
67-72 are the years they'll forsure fit. I think 66 and back have wider spacing between the knobs, they might fit a 73 and up but I think the knobs are too different and would probably not look right. Also they can be converted to FM if you want to pay about $300 I think.
Old 02-17-2006, 03:17 PM   #4
magntik
Thanks for the info.
I was thinking more along the lines of putting it on ebay.
I don't think it could compete with my Alpine deck when it comes to playing my iPod.
Old 02-17-2006, 04:04 PM   #5
Green Machine
Green Machine's Avatar
I have actually looked at 73-87 radios and the knobs are to close together to fit into our trucks and i think the face is just a little thinner. By the way welcome to the board from Iowa also.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-17-2006, 06:15 PM   #6
booth
Active Member
booth's Avatar
Did I understand you correctly, a '67 stock AM radio can be converted into a FM radio? If so where can I send one of mine out to have this done?
Thanks,
Paul
'67 Chevy LWB (Running)
'67 Chevy LWB (Not Running)
'70 Chevy LWB (In Pieces)
'72 Chevy LWB (In Pieces)
booth is offline   Reply With Quote
Old 02-17-2006, 08:24 PM   #7
davidh
davidh's Avatar
I've seen this FM conversion in a classic truck magazine and have seen people talk of it on this site. I think the only way I would do it is if my truck was very originial. I know there's several options too. You might look in the back of some truck magazine, classic truck, custom classic truck etc or search the web or post something here.
Old 02-17-2006, 08:41 PM   #8
71chevytruckguy
71chevytruckguy's Avatar
check out http://customautosound.com/ if your lookin for a radio that will fit in the stock dash. they sound real good and look good. i've got their usa-5 for my 71. it sounds real good.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Thread Tools
Display Modes
