Old 02-23-2006, 04:20 PM   #1
GruntyPants
GruntyPants's Avatar
Determining L6 Engine Size
Hello all,
I've been trying to nail down the exact size of the inline 6 in my truck and can only find from the block casting number that it is either a 230-250. The casting number is 3877178. Is there a way short of measuring the bore to see what I've got here?
Shawn
'67 Short Step
'70 Short Wide
GruntyPants is offline   Reply With Quote
Old 02-23-2006, 04:43 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Determining L6 Engine Size
Do you know if it is original? They never put 230 motors in these rigs.
Old 02-23-2006, 04:54 PM   #3
shifty
Questionable
shifty's Avatar
Well....some 67 w/6cyls did come with a 235 or I've seen threads at tne inliners site talking about it.
Originally Posted by Fred T
Easiest way to i.d. the 250 series block is the spin-on oil filter mount, just ahead of the distributor. If it's a 230/250, the fuel pump is aft of the distributor, followed by the motor mount. If it's a 292 the motor mount is between the fuel pump and distributor. The casting number you need is just aft of the passenger side motor mount (250) or fuel pump (292), should have a large GM below it.
If it's a 235 series the casting number is either above or behind the starter.
Originally Posted by Joe H
Go back and see if you can find the block casting number. It will be on distributor side about middle of the block right below the lifter covers. The head casting number does not match anything in my books. Get the block date code as well.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-23-2006, 09:50 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
65 or 66 was the last year for the 230 in pickups. Best thing to do is check the date code, cast numbers above the starter. The line will have the conveyer number CON2 which means nothing to us. Followed by the date code like D18 7. This is month starting with A=Jan, date, last digit of year. D18 7 would have been cast April 18, 1967 or 1977 or 1987. I know this doesn't help much. If you have the serial number, someone might be able to look it up for you. I don't have a code book for the serials.
If you're going to rebuild, I wouldn't consider the 230. The 250 is a far better engine. I would be looking for a 292, the tall deck block, with a lot more power.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-24-2006, 12:50 PM   #5
GruntyPants
Thanks for the info guys... according to Shifty's information, it looks to be a 235, since the casting info is right above the starter. I don't have any real good information whether this is the original engine or not. I did just notice that the transmission crossmember is missing, so maybe that happened during a swap, or someone just needed one while it was sitting around. It's really no big deal, I've got a 327 core that I'll build up for it at some point, but the 6 runs pretty good so far as-is. I do wish it were a 292... I've got a John Deere turbo unit that needs an interesting home....
Shawn
'67 Short Step
'70 Short Wide
Old 02-24-2006, 02:48 PM   #6
shifty
Questionable
shifty's Avatar
I think that info is always above the starter on the 230/235/250. Give us the number above the starter and we can break down the code to tell you what size it is, ok? It should be a series of letters and numbers.
Old 02-24-2006, 03:06 PM   #7
lilred67
lilred67's Avatar
wasn't a 235 a stovebolt??????they used them in the 50's.they are a completely different animal than a 230,250,or 292.
lilred67 is offline   Reply With Quote
Old 02-24-2006, 03:23 PM   #8
shifty
Questionable
shifty's Avatar
Not sure, all my info above was retrieved from the inliners.org website.
Old 02-24-2006, 03:40 PM   #9
Longhorn Man
Your missing crossmember is supposed to be like that. Looks crazy, but that's mounted the right way.
Old 02-24-2006, 09:56 PM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
235 went away in 63, when they introduced the 230 for trucks. Completely different block. The 235 was longer, wider and heavier than the new engine.
The newer series engine has a valve cover that in indented between every cylinder on the driver's side. The 235 valve cover is straight down both sides except for the 4 hold-down bolts. The engine in your photos is either a 230 or 250. If it's the one that came in the truck it's a 250.
Here's a pic of a 235
Fred
Old 02-24-2006, 10:48 PM   #11
GruntyPants
Wow, thanks guys... I just finished taking out the windshield and sanding the dash. I've got the glass guy coming out next week to get her water-tight. Drove her through the subdivision without a windshield... that really sucked, but it was fun to finally drive it. I'll be hauling things with it soon.
I'll have to really get the block cleaned off better to get the rest of the numbers.. I tried to rub chalk across them but could only get a partial. I'll get them posted as soon as I can.
Shawn
'67 Short Step
'70 Short Wide
Old 02-24-2006, 10:52 PM   #12
GruntyPants
Longhorn Man, I'll have to take your word for it, but it kind of makes sense since the engine is supported both front and rear, and the tranny is super short. I could see the mounting holes on the tranny and was sure I was missing something. Thanks again, I'm super happy to support this board with the great help I've gotten.
Shawn
'67 Short Step
'70 Short Wide
Old 02-25-2006, 02:46 PM   #13
pritch
pritch's Avatar
I got a 230 in mine-for now-I don't win many races, but I get 20 mpg.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 03-05-2011, 07:15 PM   #14
64_C10
Are you still running the 230? If so I wanted to ask what tranny you are using and the year of your truck.
64_C10 is offline   Reply With Quote
Old 03-05-2011, 09:41 PM   #15
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
64 C10,I doubt you get an answer.You have found a 5 year old post.
Resurection section.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-07-2011, 01:23 PM   #16
68 IRON
68 IRON's Avatar
Ya, I got sucked also. I was gonna say I have a 68 with a 230 in it. The bill of sale came with the truck and all maintenance records up to the mid 80's I believe. It says 230 cid special order. No mention on the SPID though.
68 IRON is offline   Reply With Quote
Old 03-07-2011, 06:38 PM   #17
Zeke's Garage
Zeke's Garage's Avatar
Ha! That was one of my first posts when I first signed up under 'GruntyPants'.
Zeke's Garage is offline   Reply With Quote
Thread Tools
Display Modes
