02-24-2006, 12:13 AM | #1 |
4x4 cab mounts ???S
i think i remember the cab mounts being different for 2wd and 4wd, if so what is the difference? If i had a 4x4 chassis and were going to put a 2wd cab on it would i buy the 4x4 body mounts? thanks in advance, Mike
02-24-2006, 12:19 AM | #2 |
Re: 4x4 cab mounts ???S
Yep..you would need the 4x4 body mount kit to mount that 2wd cab on the 4x4 chassis. The 3/4 tons, 1 ton and 4x4's all use the same bigger body mount rubber bushings. The difference is that there a taller rubber bushing. You'll need the same bigger bushing for the rad cradle also. It's a sepearte kit by some suppliers
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 02-24-2006 at 12:22 AM. |
02-24-2006, 12:33 AM | #3 |
Thanks Rod,where is the best place to get these,and is there anything i need to know before i order them. do they typically come with washers and bolts any info will be greatly apprecited Mike
02-24-2006, 09:18 AM | #4 |
Mike;
Rod is correct, you'll need the 4x4 mounting kit to put the 2wd cab onto a 4x4 frame. The cab it's self is the same with the exception of the removeable high hump. All 4x4's had the high hump. Some 2wd had the high hump depending on motor & tranny set-up. You have a choice between rubber & polyurethane. The rubber is softer and has more flex to it, the poly is darder and has less flex. Some kits come with all the hardware, bolts, washers & nuts. Others don't. There are several venders & links to their sites on the main page. Contact them to find out what their kits include. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
02-24-2006, 01:05 PM | #5 |
i have always been told no matter what the cab,,use the mounts for the "frame",so yes you would need 4x4 mounts..i bought mine from summit and the only bolts that came with it were the 2 rear bolts because the new mount's are a different design than the old one's and use a shorter bolt..
02-24-2006, 01:32 PM | #6 |
Bought mine from LMC, and came with ALL bolts, washers & nuts...
02-24-2006, 04:32 PM | #7 |
I just ordered a set from summit for my blazer, but they have em for trucks as well it was $78 with all the bolts, nuts, washers, and urethane bushings. Ask for the Performance Accessories kit, it is part #11008 for the 69-72 K5. It is the same as energy, but has the hardware. The stock kits cost almost $200 with hardware, so this kit is the way to go.
Thread Tools | |
Display Modes | |
