Old 07-22-2002, 03:42 AM   #1
Duner97
Duner97's Avatar
Another new guy
Been visiting the site off and on for a couple years, ya know checkin out stuff every now and then. I bought a 72 Cheyenne shortbed fleetside 4x4 about a month ago. Its been my dream truck and now i have one, so this is my new project. its gonna be one of those slowly but surely types of things. It's got a 327, turbo350 AC PB PS. She runs like a top, but wont stop for anything! it has been sitting for years, and the brakes dont work. i bought a new master cylinder, slapped it on and they worked, a lil spongy, but they stopped me! so i bled em once more and after that, no brakes, so i'm back to where i started!
72 SB 4x4
-Duner97
Duner97 is offline   Reply With Quote
Old 07-22-2002, 03:56 AM   #2
Andy4639
Old member
Andy4639's Avatar
Brakes
Have you been under it to check and see if there is fluid running out at one of the wheels. If it sat for a long period of time I would suggest a shop look at it. You said you bleed them a couple of times did you refill the brake fluid. I would check the back brakes and all the lines to see if any thing is missing.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-22-2002, 04:07 AM   #3
Duner97
Duner97's Avatar
Yup, I've looked around for a leak and found nothing out of the ordinary. I refilled the fluid level and it's fine. it just seems as if it sucked in in air. If i get time, i'll take the master cylinder off, and bench bleed it again. If it works after that, I'll have a better idea where to start lookin. I should probably go ahead and get new wheel cylinders for the rears since its probably been a while since its had new ones.
Forgot to mention, the truck is real straight except for a dent on the bottom front corner of the bed on the right side and dented rockers from being highcentered and the only rust i have found is surface rust on the floorboards... and i picked her up for $4250.
72 SB 4x4
-Duner97
Old 07-22-2002, 04:13 AM   #4
Super Chevy
Super Chevy's Avatar
Thumbs up
Nice lookin truck
hope you get your brake prob's solved...
Super Chevy is offline   Reply With Quote
Old 07-22-2002, 07:16 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Welcome from Ohio.
Brakes are over rated anyways...mine are more like delayers
Old 07-22-2002, 08:33 AM   #6
JimKshortstep4x4
Welcome from Western, MI! Good luck on your brakes, bleeding the rear brakes can be very difficult.
Instead of bench bleeding the master cylinder, we bleed after the prop valver and return the fluid to the master cylinder with plastic tubing. (If you submerge the tubing, you can bleed the brakes by yourself).
Jim
Old 07-22-2002, 09:54 AM   #7
68 with 350 TPI
68 with 350 TPI's Avatar
I would go ahead and get some new wheel cyls and then repeat what you have done.
Also make sure the rod dident mess up behind the master cyl.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-22-2002, 10:36 AM   #8
Randy70C-10
Randy70C-10's Avatar
Nice truck, welcome to the board! If you can't get the brakes to work, Summit racing sells parachutes.
Randy70C-10 is offline   Reply With Quote
Old 07-22-2002, 01:28 PM   #9
HIGH724X4
Welcome to the board!!1, From Indiana!!!
72 CHEVY FLEETSIDE 4X4 K10
(SOLD TO JAMIE72,
BUT BLAZER GAL PULLED AWAY WITH IT LOL!!!)
Will Own one Again!!!
1967 CAMARO (PRO-TOURING PROJECT)
Lawrenceburg, Indiana..
AOL IM: kbillcad
HIGH724X4 is offline   Reply With Quote
Old 07-22-2002, 04:21 PM   #10
Gordo
Smile
Welcome from Connecticut!
Be sure that the linkage is allowing the piston within the master to return ALL THE WAY BACK when released. This will give you those syptoms also. This could be from an incorrect master and or linkage adjustment/problem. Good luck and keep us posted.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 07-22-2002, 07:01 PM   #11
72BACK2NU
Oregon welcome
Good lookin truck. Good luck on the brakes. Your in the right neighborhood for fixit tips. Cya
72 GMC C1500 2WD LWB
White City, OR
As for me and my house, we shall serve the Lord.
Looking for Oregon 72 GMC donor w/PS & column-shift auto
72BACK2NU is offline   Reply With Quote
Old 07-22-2002, 07:53 PM   #12
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
welcome to the board, good to have more california members .... especily with 4x4s! id go ahead and for sure put new wheel cylinders on...... go ahead and replace the drums and everything while your at it...... the parts arnt to expensive and brakes are very important! (im saying this and like longhorn i have delayers.... lol)
68SWB4x4 is offline   Reply With Quote
Old 07-22-2002, 08:34 PM   #13
chevyman 68 C/10
chevyman 68 C/10's Avatar
Great truck and welcome to the board!!!
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 07-22-2002, 08:45 PM   #14
Wasted Income
Boosted Member
Wasted Income's Avatar
Cool
Welcome from the land of Beer and Cheese
Cool Truck!!
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-22-2002, 09:27 PM   #15
meathead95
computer illiterate
meathead95's Avatar
welcome from nashville!
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 07-23-2002, 08:42 PM   #16
Duner97
Duner97's Avatar
Hey guys, thanks for the welcome, as well as the suggestions and compliments. Once i get some time, I'm going to go get some wheel cylinders and see what that does for me. I'll check out the rod and see how it looks also.
after this problem is solved I'm going to figure out which tranny seal leaks, and replace that. the previous owner says the fluid will come out about as fast as it goes in
72 SB 4x4
-Duner97
Thread Tools
Display Modes
