fan clutch
I know we had a post about this a while ago....but I don't think this issue was addressed.....my clutchable fan seems to be on all the time....it was mentioned that when its cold, it will spin until the fluid warms up a bit.....but this fan seems to be spinning (not at engine speed, but quickly just the same) all the time???? It is winter around here....but is this normal?
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
Old Skool Club
![]() Join Date: Jun 2001
Re: fan clutch
These clutch fans have a thermostatic function in the viscous coupling that is on the face of the fan (opposite the water pump). When it is cold, it will usually be difficult to turn the fan (engine off) by hand. When the engine is hot, the fan is easily turned. All of this seems to be bass-ackwards, don't it?
Anyway, when I have seen the fan clutches fail, the fan will spin, but never fast enough to actually move any air. You should also have a fan shroud, for the best cooling effect, whether you have a fan with a clutch or without a clutch. But, for you own peace of mind, find a parts person who will let you compare your fan clutch, to a new one. Then, you'll have a better idea of what condition yours is in.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: fan clutch
They can also lock up as if there wasn't a clutch installed. Try turing it by hand while hot. If it won't turn easly, replace it with a new one. They are about $50 new last time I checked.
Re: fan clutch
can I buy just the clutch assembly?
#5 | |
blood type; Retumbo
Re: fan clutch
Thread Tools | |
Display Modes | |
