Old 03-01-2006, 03:06 AM   #1
BigShoe24
True Addiction
BigShoe24's Avatar
Air Management
So, I’m starting to buy my air system. So far I’m going to run Slam bags, RE7-single ½” port, all the way around. Using Air Ride control arms up front. My questions, what line should I go with, ½” or 5/8”? Also plan on running at least two 5 gallon tanks, with a compressor on each one, what kind of compressors do you guys like the best? Last, what values are easy to work with, pretty fast, and somewhat dependable. Any suggestion will be helpful, Thanks
BigShoe24 is offline   Reply With Quote
Old 03-01-2006, 07:29 AM   #2
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
Re: Air Management
***************** has a build your own kit link on their website. i have not purchased yet nor am i doing the same things you are, but every time i pieced together a different kit i was amazed with the price tag
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 03-01-2006, 12:43 PM   #3
hotrodhomi
hotrodhomi's Avatar
Re: Air Management
what kind of action are you looking to get out of your bags?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-01-2006, 02:55 PM   #4
fastbagged68
fastbagged68's Avatar
Re: Air Management
I have 2 5 gallon tanks, Oasis Compressor, 1/2 valves, 5/8 orffice, 1/2 line, 170 psi switch, slam specialties re & rs 72 bags. I like it and not quite finished. I also ran 12 valves, 8- 1/2" for lift and drop and then 4- 1/8 for slow drop so my Accu Air can control its height adjustment!
You don't need anything bigger then 1/2 line. - Take a straw and blow through it, now take a fuel line and blow through..... can you tell a difference. I would suspect the straw had more force..... The big line is pointless unless you have enough pressure. Also your system will only be as fast as your smallest part.
fastbagged68 is offline   Reply With Quote
Old 03-01-2006, 06:07 PM   #5
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Air Management
I dont want it to hop, but I would like it to be pretty fast. So, I need 8 valves? they only work one way? Or does someone offer a two way valve? Thanks again for the help
Old 03-01-2006, 10:58 PM   #6
canadian trucker
A day should have 30 hours.
Re: Air Management
you need one valve for filling the bag and one to deflate it now you can get valve blocks which have just 3 lines attached to them 1 air goes in from your tank, 2 air goes to the bag from the valve, 3 a small line to your gauges so you know the preasure.
anyways a valve block has two valves on it so you one for inflating and one for deflating, no need to run double ported bags or a 'T' some where between the fill valve and the bag so you can run your deflate valve..
i hope i did not confuse you because i sure did myself
canadian trucker is offline   Reply With Quote
Thread Tools
Display Modes
