03-01-2006, 08:28 AM | #1 |
67-72 Addict!
Got my new sway bar bushings on- pics
I recently cut the front springs on my truck and had to remove my sway bar in the process so I decided to clean it up. I went with Moog urethane bushings for my 1 1/16" bar (part #K6169). Fellow board member 70GMCer sandblasted my bar and brackets and primed them. I painted them body color and bought all new grade 8 hardware. I might modify the front brackets later. My question is: Did I put the bar on upside down???. I'm not sure if it matters. The reason I ask is I looked at Tx Firefighters thread in FAQ and noticed his first pic showing the bar in the grass looks like my first pic angled downward but then after he installed his it looks angled upward. I haven't driven it yet. Do I need to flip it or does it matter?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 03-01-2006 at 08:38 AM. |
03-01-2006, 12:39 PM | #2 |
Re: Got my new sway bar bushings on- pics
yeah looks right , looks good
67 swb gmc,big block cadillac powered,400 turbo,2.73 ratio and disc brakes-basically a frankenstein of many parts- |
03-01-2006, 02:10 PM | #3 |
looks good
03-01-2006, 02:20 PM | #4 |
How much difference in handling is there in those? I had 67 3/4 ton I should've pulled it out when parting it. But I have a 67 parts truck that has one. I thought of doing this with it when I rebuild the front end.
03-01-2006, 02:25 PM | #5 |
67-72 Addict!
Thanks guys. I haven't driven it yet with the new bushings, my old rubber ones were all shot!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-01-2006, 02:40 PM | #6 |
67 is sold
Nice work
03-01-2006, 02:51 PM | #7 |
Nice work, that's cool you painted it to match the truck. It probably looks funny because you are using stock height brackets witha lowered truck. ECE sells lowered brackets for $20, but what you have should work just fine
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-01-2006, 02:55 PM | #8 |
Do the sway bars make a noticeable difference in handling?
03-01-2006, 03:00 PM | #9 |
Not to steal, but I have one and it looks to be a 7/8", is that stock? I have seen the 1 1/16" as well. Were they both offered? I couldn't find urethane bushings for the 7/8", anybody know where I can get em? Wes, do you have these in urethane?? Any help would be appreciated. Yes, a sway bar makes a huge difference! When I turn my 2wd short bed with BBC it leans hard so the bar keeps it from leaning.
03-01-2006, 05:08 PM | #10 |
67-72 Addict!
If I remove the factory brackets I will just drill new holes and mount it directly to the frame like Frizzle Fry did on his Burb. I have only seen 7/8" bars offered for the rear by the vendors. I thought 1 1/16" was the smallest for the front. Maybe a vendor will verify this.
03-01-2006, 06:46 PM | #11 |
yes you could get the small 7/8 bars. 1 1/16 were heavy duty .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-01-2006, 06:50 PM | #12 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-01-2006, 08:45 PM | #13 | |
03-01-2006, 09:09 PM | #14 |
18 Till I Die
Are those poly bushings or rubber. Can you buy poly??
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
03-02-2006, 09:01 AM | #15 |
67-72 Addict!
davidh- I haven't driven it yet with these new ones but the bar will stiffen your front end to prevent lean.
Kelsfine69- Mine are the urethane type I bought locally for $24 for all.
03-02-2006, 04:22 PM | #16 |
Yeh....I did do a good job on that, didn't I ......lol
Looks good Jim.......see ya Saturday........
1997 GMC Sierra Ext 1965 Mustang |
03-02-2006, 04:40 PM | #17 | |
Keepin an eye out
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
03-02-2006, 04:44 PM | #18 | |
Keepin an eye out
03-02-2006, 05:57 PM | #19 |
I snaked one from a 97 hoping to use it, but I am doubting I can get it to work. I pulled mine from a 67 3/4ton and it's the 7/8, but for now it is better than not having one at all. I'll have to scan the junkyards to see if I can locate a late 70's early 80's if they'll work?!
03-02-2006, 05:59 PM | #20 |
67-72 Addict!
I heard you can go up to 87'.
03-02-2006, 06:27 PM | #21 |
Looks good..Are you getting any noise from the poly bushings? Heard somewhere that they tend to squeek. Enlighten me.
72 Chevy C10 Custom Deluxe 03 Camary (Family Ride) 96 Jetta (piece of sh**) |
03-02-2006, 07:16 PM | #22 |
Watch out for your cornhole !
If you want the heavier bar, you'll need a 3/4 or 1 ton unit. They go through 91 on heavier trucks. The 1/2 ton changed body style in 1988, but the heavier trucks kept the same old body style for another 3 years longer.
03-02-2006, 07:17 PM | #23 | |
03-02-2006, 11:57 PM | #24 | |
You just have to grease them well.
03-03-2006, 12:17 AM | #25 |
67-72 Addict!
These Moog bushings have no zerk fittings and the directions specifically stated to "Not" use any grease or they will develop a squeak. I'll see in time how they work.
Thread Tools | |
Display Modes | |
