Old 03-02-2006, 03:33 AM   #1
Ice68
Ice68's Avatar
59 Chevy Replacement Panel?
I'm working on my '59 Chevy Truck. I took off the fenders, and I noticed some rust at the bottom of the front cab near the door hinges ( It's where you bolt the fender to the cab). Does anyone know if they make replacement parts for the front cab area near the door hinges?
'68 Chevy Truck C10 LWB 292 engine 3spd Tranny Everything Stock except for shaved bodywork.
'72 Chevy Truck Custom Deluxe 2WD LWB 350/350 HEI Tilt PS AC Dual Exhaust
Ice68 is offline   Reply With Quote
Old 03-02-2006, 11:55 AM   #2
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 59 Chevy Replacement Panel?
I know LMC sell two small replacement panels for the bottom front corners. I bought them myself. You can go to the web site and order a free catalog. Here's the web site.
http://www.lmctruck.com/
CAL 58 GMC is offline   Reply With Quote
Old 03-02-2006, 02:28 PM   #3
thebeemanone
thebeemanone's Avatar
Hi
I got mine from Good mark.
If you can read this, thank a teacher. If you can read this in English, thank a vet. 1959 Chevy http://www.cardomain.com/ride/2283573
2004 Chevy 2500 HD Crew Cab http://www.cardomain.com/ride/2283576
thebeemanone is offline   Reply With Quote
Old 03-02-2006, 02:51 PM   #4
Norselander
Clunker Farm, Proprietor
Norselander's Avatar
http://www.oldtruck.net/links/partsservice.shtml
(scroll down to "multiple systems")
Drew
Chief Junk Jockey
Norselander is offline   Reply With Quote
Old 03-02-2006, 06:16 PM   #5
Ice68
Ice68's Avatar
Thanks for the reply. I'll try to get pictures posted of the bottom front corners that I need to replace.
Thanks,
Leroy
Old 03-04-2006, 04:01 AM   #6
Ice68
Ice68's Avatar
Here a picture of the bottom front corner of my '59 cab. Any suggestion or input in repairing it would be appreciated.
Thanks,
Leroy
Old 03-04-2006, 04:11 AM   #7
Ice68
Ice68's Avatar
Here's a pictures of the driver side. Any suggestions for repairs.
Old 03-04-2006, 07:52 AM   #8
CAL 58 GMC
CAL 58 GMC's Avatar
Yep, mine looked the same way. That is a common place for rust that goes un-seen until you take the fenders off. Over the years dirt and leave build up from the cowl vent and when it rains it washes it down to the bottom corners, stays moist and starts to rot away. Replacement metal is out there. There are two replacement panels for each side. I got mine from LMC and sure most other classic truck parts shops sell them.
Old 03-04-2006, 11:57 PM   #9
55ChevyPU
55ChevyPU's Avatar
you asked me for a pic in another thread
I cut out the bottom section of that air vent.
55ChevyPU is offline   Reply With Quote
Old 03-05-2006, 12:22 AM   #10
Ice68
Ice68's Avatar
Thanks for the pictures, 55ChevyPU.
Old 03-05-2006, 10:16 PM   #11
CAL 58 GMC
CAL 58 GMC's Avatar
Hey Ice68,
Here's the panels out of LMC's catalog I was talking about. Panels 2 & 3 in the photos is what you would need. Part 2 is the hinge pillar (38-7924 LH & 38-7925 RH) at $39.95 each and Part 3 is the hinge pillar lower iner pocket (38-9066 LH & 38-9067 RH) at $29.95 each. Here's a link to LMC's web site. http://www.lmctruck.com/You can order them online or order a catalog. I hope this helps and good luck!
Old 03-06-2006, 03:35 PM   #12
Ice68
Ice68's Avatar
Thanks CAL 58 GMC for the info.
Thread Tools
Display Modes
