Old 03-02-2006, 11:11 PM   #1
krue
Designated A-hole!
krue's Avatar
Temp control for electric fans
What's the best way to wire my fans. On all the time, or temp controlled but both operating at the same time, or one for normal loads and the other for high loads? I'm doing this on a shoestring budget so keep that in mind.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 03-02-2006, 11:32 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Temp control for electric fans
Definitely run a thermostatic switch to turn them on when needed only. Use a relay to control it, as the fans pool a lot of amperage.
Find a temp switch that has a temp range you're comfortable with, whether OEM or aftermarket from someplace like Painless Wiring.
Old 03-02-2006, 11:54 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
Try here
http://www.flex-a-lite.com/auto/html/vsc.html
There is a simpler one that you can adjust manually, I will see if I can find it
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-03-2006, 12:01 AM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
Or Here
Part# 31147-Adj. Temp Sensor
http://www.flex-a-lite.com/auto/html...cessories.html
or
http://www.derale.com/electricfanaccess.shtml
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 03-03-2006, 12:01 PM   #5
farside847
farside847's Avatar
On that topic, what is the optimum temp for an engine? Im sure there is such a thing as "too cool" and definately "too hot". Where is the nice middle temp? (feel like goldylox)
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-03-2006, 12:08 PM   #6
67chevemall
67chevemall's Avatar
Just watch your temp gauge and use a switch on the relay
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-03-2006, 12:12 PM   #7
jhow66
jhow66's Avatar
Anything above 180*.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-03-2006, 12:29 PM   #8
beater69
Sinister Exaggerator
beater69's Avatar
I've seen alot of performance vehicles running lower thermostats like 150 and 160. anybody got an opinion on that? I guess thats a silly question, of course someone has an opinion on that
beater69 is offline   Reply With Quote
Old 03-03-2006, 12:40 PM   #9
krue
Designated A-hole!
krue's Avatar
That's a good way for me to wind up on the side of the road!
www.daveramsey.com
Old 03-03-2006, 01:01 PM   #10
northcountry67
northcountry67's Avatar
I'm not sure about performance cars, but up here we want it as warm as possible without overheating. I run 180-185 in most everything.
northcountry67 is offline   Reply With Quote
Old 03-03-2006, 01:48 PM   #11
76bonanza
76bonanza's Avatar
I run a 190 deg thermo works great, heater is very nice also.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-03-2006, 01:58 PM   #12
72MARIO
72MARIO's Avatar
If they motor does not get hot enough the oil can not boil out the contaminats. 160 is TOO COLD. All new cars run a 195 or hotter. Even the 86 truck came with a 195.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-03-2006, 02:28 PM   #13
farside847
farside847's Avatar
Next question.... What is the temp on a stock guage? Mine normally runs at the line to the right of cold. It never hits the middle of the guage. Anyone know the actual temps for the lines on the stock guage?
Old 03-03-2006, 03:27 PM   #14
49studebaker
49studebaker's Avatar
I've heard of some running two fans where one runs off a thermostat and the other one comes on whenever the air conditioning is on. Don't know if I necessarily agree with that, but the idea I do like is others use an override switch mounted on the dash. During hot days in traffic or pulling a grade, it can be manually turned on. Temperatures between 180 and 200 degrees is what most seem to be set at.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 03-03-2006, 03:36 PM   #15
jhow66
jhow66's Avatar
Start of line is 180*--that is what mine shows with a extra mechanical gauge at 180*.
Thread Tools
Display Modes
