Old 03-03-2006, 07:29 PM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Clutch adjustment???
When I push the clutch in on the Blazer all the way, she starts to make a screeching noise. Should I loosen it up, or tighten it. Its tough to get in gear too, if that helps any. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 03-03-2006, 10:27 PM   #2
Green Machine
Green Machine's Avatar
Re: Clutch adjustment???
The screaching noise may be a bad throw out bearing. The clutch linkage may work better(easier) if you put the rod in the hole next to the spring. The clutch is adjusted properly if you have about 1 inch of free play at the top of pedal travel.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-03-2006, 11:59 PM   #3
kwmech
I agree, move the rod to the outer hole, it will slow down the amount of throw.
With the rod on the inner hole the bearing may actually be traveling too far and that could be your noise.
Old 03-04-2006, 09:04 PM   #4
red71cheyenne
Back in the sticks
Thanks, I'll move it and let you guys know what it does. The throwout bearing and clutch/pressure plate are all new. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Thread Tools
Display Modes
