15X8 back spacing
Ive got 15X8 & 15X7 truck rally wheels. does anyone know the backspacing on these wheels. Id check myself, but its @ the body shop & well, Ive got a wild hair to order new wheels
75 GMC C-15 short/step factory 454, lowered |
Re: 15X8 back spacing
Im thinking about 285/70/15s on the rear, so I need to make sure the backspacing is the same. id consider 15X10s also if I know what backspacing will fit. John
75 GMC C-15 short/step factory 454, lowered Last edited by stepside454; 03-11-2006 at 02:33 PM. |
paper or plastic?
a 285/70/15 will fit on your stepside with a factory 15x8 rally wheel
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
Grande, sweet, I was sure they would...but do you know what the backspacing on the stock 15X8s . I plan to buy new wheels. where in MO are you BTW
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've measured them to be 4.25 inches backspacing.
That's tape measure from the back of the flange to the edge of the rim on the inside.
TX Ok so 4.0" back spacing is what I thought...just wanted to be sure. I probably outa wait till monday, pull a wheel off & measure myself, but I got a hair to order em now
15x8" ralleys are 4" bs (4.25~4.5 counting the lip & depending on how you measure).
You could go 15x9 w/a 4" or 15x10" w/a 5" bs using that 285/70. I would go 10's personally. I have 10's on the rear of mine w/5" bs & @ least 7" of drop.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-11-2006 at 04:30 PM. |
Scoti, you have some pics Icould see of yours with 10 wide . Now mine is a stepside, dont know if that matters. John
#9 | |
paper or plastic?
btw 12" wide will fit with a "little" trimming ![]()
Thread Tools | |
Display Modes | |
