Old 07-23-2002, 10:56 PM   #1
brad69C-10
Need bolts for door hinges...........
My bolts that held my hinges to the cab and the doors were in pretty bad shape............does anybody have these bolts or sell them new? Thanks
69 C-10 Pro Street...........red on black...........big block and a lot of go fast stuff under the hood
Still in progress ...........
brad69C-10 is offline   Reply With Quote
Old 07-23-2002, 11:02 PM   #2
Benrs86
Benrs86's Avatar
i thought they were just regular bolts??
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 07-23-2002, 11:06 PM   #3
brad69C-10
could very well be....just wanted to make sure they weren't something special I guess.........cool........Thanks
Old 07-23-2002, 11:34 PM   #4
Benrs86
Benrs86's Avatar
oh, well im not sure they are, but most likely. i just put my original ones back, but if i were you i would just get some stainless steel hex head bolts and maybe washers? i dont see why a regular bolt wouldnt work? i dont know. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 07-23-2002, 11:53 PM   #5
Shane
Shane's Avatar
not sure of size...but they are Fine Threads....
Shane is offline   Reply With Quote
Old 07-24-2002, 12:05 AM   #6
crazy longhorn
Fabricate till you "puke"
They are 3/8 24 NF ,& have a flatwasher . hardware store stuff will be a little different on the head,but usable(unless doing a correct resto).........Al
crazy longhorn is offline   Reply With Quote
Old 07-24-2002, 07:33 AM   #7
JimKshortstep4x4
Smile
I would suggest that you try to pick up the regular hinge bolts. Someone on the board should have a set. The bolts have large thick washers that are cupped to bite into the hinge to prevent movement of the hinges. Since stainless has a tendacy to stretch,
it may create a problem of having to constantly retighten the fasteners.
Jim
Thread Tools
Display Modes
