Old 03-12-2006, 08:22 PM   #1
mr.wilson
Old Air Products Hurricane system!
Well, I bit the bullet and ordered thier Hurricane kit and it should arrive Monday. I will be taking pictures and documenting all the installation. Leave feedback if you have any.
Thanks,
Wilson
Wilson
1972 Cheyenne LWB, 350ci TH-350.
Restoration in progress.
mr.wilson is offline   Reply With Quote
Old 03-12-2006, 08:27 PM   #2
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Re: Old Air Products Hurricane system!
Looking forward to your posts & lots of photos of the install. Planning an AC install myself in near future. Thanks !!!
68shortstep is offline   Reply With Quote
Old 03-12-2006, 10:12 PM   #3
matthufham
old air.. is that in fort worth?
matthufham is offline   Reply With Quote
Old 03-12-2006, 11:20 PM   #4
formula_raider
I am about 80% done with my Old Air Hurricane system for my 72. So far everything has been pretty straightforward and fits nicely. It really cleans up the firewall nicely. The only thing that I had to tweek was the receiver dryer aluminum lines in the front by the condensor. I had to maybe bend them with my thumb about a 1/4" to make sure they dont hit each other. No problem....heck it even says that you might have to do that in the instructions. Only thing I have left to do is install the pressure and return lines and charge the system.
formula_raider is offline   Reply With Quote
Old 03-13-2006, 07:22 PM   #5
72armyswbtruck
72armyswbtruck's Avatar
Awaiting pictures.....
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-13-2006, 07:57 PM   #6
dennislbrooks
dennislbrooks's Avatar
I used Old-Air and had no problems that they would not help me with.
dennislbrooks is offline   Reply With Quote
Old 03-13-2006, 10:33 PM   #7
formula_raider
Here are a few pictures; I still need to install the heater hoses and hi pressure hose.
Old 10-05-2016, 12:57 AM   #8
Jason7121
Jason7121's Avatar
Just bought the old air kit for my 71 c10. On the inside where the provided plate goes does it just sit up against those raised areas where old heater unit was or did you grind that lip down
Jason7121 is offline   Reply With Quote
Old 10-05-2016, 05:45 AM   #9
72MARIO
72MARIO's Avatar
Hope you like it. I will be removing mine this winter and installing a original ac system. I have had problems with it fogging up the entire inside of my cab when going from ac to heat. Old air has been no help at all to fix the problem
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-05-2016, 05:57 PM   #10
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
That thing hangs way down low under the dash. Does it not affect the glove box or something?
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Thread Tools
Display Modes
