Old 07-24-2002, 12:14 AM   #1
Johngear67
The Mighty Blue Bottle
What's the lowest I can go without a C-notch?
Hi all, I need to know just how low one of these trucks will go without needing a c-notch a keeping the truck level.
Front springs, spindles, rear springs and would I need to concern myself about shock travel.
1967 Chevy C 10 Custom
350 780 cfm 467 lift 278 dur
ported&pollished
2400 stall 350TH
B&M shifter
175 shot of nitrious
Johngear67 is offline   Reply With Quote
Old 07-24-2002, 12:30 AM   #2
Shane
Shane's Avatar
You can go up to a 5" drop in the rear without much trouble....you may hit the bump stops on potholes and such....but not usually. You will need an adjustable panhard rod for anything more than 3-4 inches in the rear though.
Hope this helps.......
Shane is offline   Reply With Quote
Old 07-24-2002, 12:34 AM   #3
Johngear67
great to know but what about the front 5" as well?
ported&pollished
2400 stall 350TH
B&M shifter
Old 07-24-2002, 12:39 AM   #4
crazy longhorn
Fabricate till you "puke"
If you want the truck level, you might go with a 2 1/2" spindle up front. there wont be any problems with shock lenght up front (with a spindle),& at the rear you can get a relocator bracket set to stand the shock back up . good luck.....Al
crazy longhorn is offline   Reply With Quote
Old 07-24-2002, 08:46 AM   #5
Low69CST
You may also want to cut a little bit of the coils off the front springs to set the front down with the rear. I would just put in the spindles, then if the front isn't low enough pull the springs out and cut a little less than 1/4 of a coil out of the springs.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-24-2002, 08:52 AM   #6
Frank_Zeller
Frank_Zeller's Avatar
Have ECE 6 inch rear drop with air products air bags in springs. You need to cut the rear bump stop 1 inch shorter. Someday I migh put the C notch in. But...........now days it looks like you can bag the rear for about a 100 more than the ECE 6 inch spring drop kit. Might be a better way to go.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Thread Tools
Display Modes
