Old 03-13-2006, 10:32 AM   #1
atcavage
Converting to automatic
So I am tired of my column shifter and want to convert it to an automatic. I don't want to turn it into a floor shifter either. Has anyone done this to a 3-on the tree? I gather I'll need a new column and transmission, but is this something that someone who is slightly more mechanically inclined that I am will be able to do? And would it be cost-prohibitive? I would really like a new paintjob with some body work, but things related to the truck actually moving seem more important. Thanks.
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 03-13-2006, 10:51 AM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Converting to automatic
You will need a tranny/flywheel/auto crossmember/tranny cooler/tranny lines/auto column/vacum line for tranny. The swap is fairly easy. i did it years ago. Look in the faq section. i think there is a topic on this in there.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 03-13-2006, 12:27 PM   #3
farside847
farside847's Avatar
I have thought about this also.. But have not done it. Yet.
Auto Trans
- 200-4r (33% OD) or 700r4 (30% OD)
- need tv cable, and lockout kit
- LOKAR linkage suggested, long version
- new auto column
Flaming River $300 FR20003
Ididit $$$$
Rebuilt Stock unit $400 from Brothers
Used One $50
- new auto crossmember from TH400 does fit. need new rubber mount
- Shorten/new driveshaft?
length of 2004r tranny is the same as 3sp
yoke? 350/400/700r4/2004r use 27 spline,I think the 3sp did too
- Replace flywheel, Auto flexplate, ringgear, starter
- transmission cooler and lines
Let us know if you do it and post pics!!!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-13-2006, 02:51 PM   #4
davidh
davidh's Avatar
I've even seen people get by using the 3speed column with the automatic.
davidh is offline   Reply With Quote
Old 03-13-2006, 07:19 PM   #5
72armyswbtruck
72armyswbtruck's Avatar
wow, talk about some money that can add up quick
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-13-2006, 08:43 PM   #6
project1971
project1971's Avatar
Farside you said the 200r4 is same length as the 3 speed how much differance is the 700r4? i am doing the same conversion when i do the tpi set up and was wondering the same questions.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 03-13-2006, 09:13 PM   #7
farside847
farside847's Avatar
I think its like 3 inches off. You would need your driveshaft shortened... But any driveshaft place can do that.
Old 03-13-2006, 09:38 PM   #8
atcavage
Wow, I am so paying someone to do this. I think that instead of buying a new car, I may just spend the money and get my truck into as perfect mechanical shape I can.
I think I'm gonna try and skip getting a new column if I can (tilt would be nice though) and save the cash. If I convert it, 75% of my problems would be gone. Of course the only question left is, do I add power steering too?
And then there is getting a new bumper, a new grille, fixing the window, the wipers, new lenses and chrome, a new antenna, a new seat, new dash cluster, a new paint job... The list just goes on and on.
I really love my truck.
Old 03-13-2006, 11:02 PM   #9
project1971
so can i use a 1 piece shaft from burb or late model and get cut to length? was a 2 piece shaft on a long bed
2008 Ford FX2 Screw
Thread Tools
Display Modes
