Old 03-14-2006, 09:11 PM   #1
ItsNotABlazer
The full convertible guy
ItsNotABlazer's Avatar
About to order rear drop springs....
I have a 64 C10 I have started redoing. I was wondering if the adjustable panhard bar is required when using drop springs in the rear? I am most likely going to order a 3 or 4" drop spring along with the new trailing arm bushings, new u bolts, shocks etc etc. I am using a 5 lug rear end which I assume is from a 71+ truck as it appears to look the same as the stock 64 except it has 5 lug axles. It was under a 66 parts truck I bought.
Brad
2012 Kawasaki Vaquero (Lime Green)
2000 BMW 740iL
1995 Chevy ECSB riding on air
1975 GMC Jimmy 2WD lowered 4/6
1972 Chevy Trazer soon to be roadster
1965 Mustang 289/3 speed (friends dad bought it new)
1964 Chevy C10 (dad bought it new)
ItsNotABlazer is offline   Reply With Quote
Old 03-14-2006, 09:20 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: About to order rear drop springs....
The guys at ECE told me I had to change the frame mount for the panhard bar on the frame on my 64 model if I put a 65 and newer rearend into the truck.
You'll notice your stock 64 panhard bar runs from the frame to a large metal bracket on the right axle tube. But, on your later model 5 lug rearend, the panhard locates to a stud atop the center pumpkin of the differential instead of a bracket on the right tube.
Terry at ECE told me to change the frame mount over to a 65 and newer one and then use a 65-72 model panhard setup.
In my opinion, you'd be advised to use an adjustable panhard bar with the 4 or 5 inch drop.
Old 03-15-2006, 01:53 PM   #3
SIR
SIR
SIR's Avatar
...also if your truck is a "fleetside",you might have to trim 1" out of the rear weel well lip for good clearance....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 03-15-2006, 02:14 PM   #4
ItsNotABlazer
The trucks are out at my land so I will have to go out there and check. I am thinking someone might have just swapped in some 5 lug axles into the 66 rear end cause I do not recall the wheel well being trimmed any. Any way to ID what year rear end it is? Thanks for the replies guys. I always double and triple check all this stuff before ordering. One of the many great reasons to have this board.
Brad
2000 BMW 740iL
Old 03-16-2006, 06:29 PM   #5
ItsNotABlazer
Firefighter I saw today what you mean about how the panhard bar attaches to the rear end. Luckily I have the 66 for parts and I guess I can just bust those rivets holding that mount to the frame and use it with a bit of welding right? The one that was under the 66 was on an ear to the side of the pumpkin. I assume thats what you were referring to. Going to check out a few more things and then get to ordering some stuff. Thanks
Brad
2000 BMW 740iL
Old 03-16-2006, 10:19 PM   #6
shortbed70
shortbed70's Avatar
I have a 65 chevy fleet and I had the bar on the pumpkin but now its on the right trailing arm. I think it was like 63 and later that had the onees mounted on the axle tube.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-16-2006, 10:45 PM   #7
ItsNotABlazer
Thats definitely different than any I have seen. I was thinking the panhard bar had to be attached to the rear end itself for centering purposes ........I am far from an expert though trust me lol.
Can you get a better pic of how it attaches to the trailing arm please?
Brad
2000 BMW 740iL
Thread Tools
Display Modes
