03-17-2006, 07:30 PM | #1 |
Anybody have an opinion on axle width for a jeep?
Im trying to come up with a good width for my cj-7. I currently have a full width dana 60 front and a 14 bolt that has been cut to 62.5 inches. The bad thing about the 14 bolt is it was cut for a fj-40 and the pinion is offset to the right 6 inches. Ill probably end up selling that and cutting down a different 14 bolt. anybody know a good width to go?
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
03-25-2006, 04:47 PM | #2 |
Re: Anybody have an opinion on axle width for a jeep?
a full width 14 bolt should be fine, since the dan 60 is still full width. Shouldnt be any problems there...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
03-25-2006, 11:47 PM | #3 |
The Blazer King
If they stick out too far just use a deep backspacing wheel like 5 inch.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
03-26-2006, 12:19 PM | #4 |
If you are OK with the width of the 14bolt go ahead and use it. I wouldn't be concerned about the off-set. The u-joints don't car which direction they are correcting.
Back in the late 80s I put a front axle in the rear of an 87 C20 to give it four wheel steering. The axle was totally stock from a replacement parts standpoint. That makes it far easier and cheaper to repair, should it be necessary. This put the differential well off-center with no problems what so ever. |
03-26-2006, 02:33 PM | #5 |
You could go with a Cab&Chassis 14bolt. They are 63"WMS instead of 67".
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
04-03-2006, 09:55 PM | #6 |
So running a offset rear and a centered transfer case output wouldnt wear out u joints or break them easy? I planned on cutting down the front 60, if i dont go full width. Im really considering going full width though. With a huge offset wheel, i guess it wouldnt be all that bad. maybe some humvee wheels.
04-04-2006, 01:50 AM | #7 |
A guy in the club my brother is in runs full width on his XJ.
Some pics http://www.sr-kanyonkrawlers.com/owy...__03_19_06.htm My bro has the Toy
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-15-2006, 10:05 AM | #8 |
PROJECT 7DEUCE
My buddy terry has an eaton in the rear of his yj heres a few shots of it.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Thread Tools | |
Display Modes | |
