Old 03-17-2006, 08:57 PM   #1
kevncar
Active Member
kevncar's Avatar
posi, limited slip, open
I am going to convert the rearend of my 67 over to 5-lug axles and thought while I was in there I might upgrade the rearend to a posi. My question is what is the difference and what should I be shopping for?
My truck is a toy, meaning I don't commute in it or anything, but I want the wife to be able to use it as a back up if something was to happen to one of our daily drivers. I also might try towing a boat or maybe a car trailer every once in a blue moon. Other than that, ITS A BURNOUT MACHINE!!!
From friends I get everything from "leave it alone" to "put a spool in it, or weld the spider gears"
Looking for that good advice I always get here. Maybe even some idea of brands and what I should expect to pay.
Thanks guys and gals
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 03-17-2006, 09:08 PM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: posi, limited slip, open
Go with a posi rear, it's super better than non posi. As for the ratio try to avoid 4:11's depending on the motor and tranny combo the revs will be super high. I would go with 373's or so they work well for towing and seem to do better on gas mileage.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-17-2006, 09:31 PM   #3
boraxman
Keepin an eye out
boraxman's Avatar
I put a Eaton posi in mine with 3.42 gears. Mines a burnout machine too
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-17-2006, 09:41 PM   #4
409biscayne
409biscayne's Avatar
I wouldn't put a spool in it unless it is a drag truck . I have a mini spool in my 68 and its a pita , especially with street tires . ( its not too terrible with slicks)
I bought a new eaton posi unit on ebay for $205 that i'll be installing soon , so i can street drive it more . You might also consider the factory posi , you should be able to find one with 3.73 gears relatively easily .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 03-17-2006, 10:13 PM   #5
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
Originally Posted by kevncar
...My question is what is the difference...
  • Open = The infamous "one wheel squeel" not recommended for a burnout machine, you'll look like a dork.
  • Limited Slip - Has clutches to allow one wheel to spin independant of the other. Will try to keep them turning at the same rate until the torque need differs enough to make the clutches slip. Also known as a positraction - but that's really a GM trademarked name (about $400 for an Eaton (non rebuildable)). There's been many names for these by different manufactures - most units use the same princibles.
  • Spool - Keeps both wheels turning the same speed ALL of the time. Basically eliminates the "differential" part of the differential. Tires will squeel when manuvering tight turns. If you've got tires that hook up, be sure to get it pointed in the direction you want to go. Recommended for racing applications only (yes, I've run them on the street, and they're lots of fun). You'll get the best looking burnouts with these (about $200).
    Other options under this category with the same effect would include welding the spiders, and mini spools. Welding spiders is very cheap (about $0), get someone experienced at it or you will ruin your rear. Mini spools are not available for all applications (they are for GM 10 and 12 bolts) - you'll need to look around (about $85).
  • Other units you didn't mention are lockers, and there are lots of those too, air, non air, etc. They click and are mainly used by off-roaders.($??)
You will need to get someone to 'set up' your gear set if you go with a full spool or a new carrier (posi, eaton, etc.).
...Other than that, ITS A BURNOUT MACHINE!!!
If you've got the money get a LS unit.
(D)
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
Old 03-17-2006, 10:25 PM   #6
Welded spiders,spool,and locker are all the same results.Both wheel turn all the time.So,the results are maybe too much traction for times like going around a curve or making a turn.The inside wheel needs to spin slower and it won`t.So,it`ll squeal with the least bit of throttle.Drifting through the turns will take care of that.But,limited-slips are made for this reason.They will act like an open differential until one wheel starts to spin.Then the other will lock-in to give a posi effect.To me,the limited-slips are more user friendly.But,with a conscience effort,a posi is a sure-fire way to gain maximum rear traction.
Old 03-18-2006, 12:16 AM   #7
CochinoFilipino
CochinoFilipino's Avatar
Limited Slip Differentials (posi, trac-loc) use clutches. And as the name implies it does slip. How much it slips, depends on how tight it is set-up. And the clutches wear out over time. One thing to consider when buying is if the unit is rebuildable or will it need to be replaced.
An automatic locker (like powertrax) acts as open differential until one wheel starts spinning too fast. Then it Locks up, 100% locked, NO slip. And people are using these in Hot Rods, it's not jus for off-roaders.
Some info here http://auto.howstuffworks.com/differential8.htm
We expect some video after the install.
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
Old 03-18-2006, 08:56 AM   #8
Auburn Gear makes a real nice unit for the street.I have one in my`90 K/5 with 12.50/33" tires and it`s tough enough for that.
Old 03-18-2006, 10:58 AM   #9
70c10
67-72 Addict!
70c10's Avatar
kevncar-I bought my Eaton posi from Toms Differentials.com out in California for $280 3 years ago and it's been good. I recommend them since you live out that way.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-18-2006, 11:02 AM   #10
truckdude239
truckdude239's Avatar
welding the spider gears is never a good idea if done wrong would be looking at a bigger repair bill
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-18-2006, 02:26 PM   #11
409biscayne
I just checked out Toms website , it looks like they also have a store in N. Idaho , close to me I'm calling them monday for axles for my 68 , woo hoo Thanks for the info .
Can-Am Motorsports
Old 03-18-2006, 05:53 PM   #12
LONGHAIR
Whatever you do .......STAY AWAY from the welded spider thing and anyone who recommends doing it. Not only is it bad for the internal parts of your axle, it is very dangerous. .............I'm willing to bet that someone will come in and say "I've had one for years, it's fine, blah blah blah". DON'T DO IT, it will break and at the worst time too.
Also I would stay away from any of the more intense locker type units too. You stated that you need the wife to be able to drive it too, so stick with the more "user friendly" units. That generally means a clutch type unit. Also, have it installed by a professional. You can cost yourself a lot of money trying to do this with-out the experience/know-how. Some will say that you can "get by" with changing carriers as long as you don't change the gears...as long as they are willing to pay for the new parts if it fails.....go for it. Otherwise, it is really better in the hands of a pro.
LONGHAIR is offline   Reply With Quote
Old 03-18-2006, 09:24 PM   #13
Riles72
How much is a factory .411 12 bolt limited slip from a '68 1/2 ton worth? Anybody know?
72 Chevy short stepside
350/350
tilt, vintage air a/c
sunset Orange Metallic paint
Early Classic 2.5/4 drop
eagle series 211 wheels
Riles72 is offline   Reply With Quote
Old 03-18-2006, 10:46 PM   #14
70c10
67-72 Addict!
70c10's Avatar
I think I paid an extra $25 for bearings and races.
Jim
Old 03-19-2006, 08:41 AM   #15
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
Just alittle off topic, but still relevant...
That car had welded spiders the first year we ran it, mini-spool after that (full spools are not allowed). Many of these cars have them - BUT, these cars are ALOT safer than street cars. The rears in these cars take way more abuse than anything on the street. It's the gears that get demolished first, not the welded spiders/carriers. Please save the flames for lighting camp fires.
1987 Camaro z28
My Truck
Old 03-19-2006, 10:31 AM   #16
Is that an asphalt car?I thought it was dirt track?Either way,racing is racing and street is street.Honestly,you wouldn`t want a spool or welded spiders on the street for long.And,one thing breaks in the rear,others are effected.I call it the "blender effect".
Old 03-19-2006, 10:49 AM   #17
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
Yes - asphalt. Dirt is for farming. Agreed on the racing/street thing, that's why I said alittle off topic (or at least that's what I meant). Also agree about the spool, etc. The one I ran on the street was a pretty serious barely-streetable car. Love the "Blender effect" phrase! Please consider that stolen.
1987 Camaro z28
My Truck
Old 03-19-2006, 11:19 AM   #18
SSC's76
No No
SSC's76's Avatar
When both wheels have traction it reduces the amount of tire shreading time to at least half so keep that in mind.
I like lockers, there cheap, easy to install and effective traction devices that you can do yourself with no special tools or need to measure. It's just slightly more difficult to install then a stock spider assembly. I had sold my powertrax no slip unit a few months back to somone who needed it badly and dident have time to wait for one to be ordered in. The no slip units are nice and rarely make noise but will chirp around corners if you take then tight and fast and once in a while you will hear clicking but it's normal. They sell a Lock Right under the Richmond name and a True Trac under Detriot which costs even less. These are the easyest to install, have the fewest pecies, are stronger IMO and the best part the least expensive peices you can buy. The draw back is they are more agressive and like to click alot with a few strange pops once in a while as the teeth lock and unlock around turns. This is what I ended up with in my 76. The lock right isnt bad in a DD but the no slip is better suited for daily use. Since you use this truck for toy/emergency use I would say the Lock Right would do nicely and is usually $100 cheaper ($320) then the No slip which is $330. Either one will would suit your needs and is just as effective as a spool but safer with less stress on the axles.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 03-20-2006, 10:34 AM   #19
D Terry,you have my consent
That`s the only problem with us hillbilly engineers,we have to make up our own names for all that technical stuff.
Dirt`s for farmers?I like that.I guess farmers like it sideways.
Old 03-20-2006, 10:41 AM   #20
boraxman
Keepin an eye out
boraxman's Avatar
Has anyone tried a ARB air locker? I just put one in my Toyota 4x4. Totally selectable, very cool!
ZIP 91351
Old 03-20-2006, 10:45 AM   #21
Swbman
Definitely spend the extra scratch for limited slip, my son tore his peg leg rear end up housing and all getting wild and crazy with the 383 stroker in his truck...
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 04-12-2006, 10:32 AM   #22
SB406
FORD is a 4 letter word.
SB406's Avatar
Just to throw in my $0.02......I just put a Detroit true trac in mine & it is sweet. The true trac is a limited slip unit that behaves like an eaton or auburn. The difference is NO CLUTCHES and NO CLICKING TEETH. It has a helical / planetary gear setup that is pretty slick. If anyone is interrested jump on detroit's web site to see an exploded view.
http://detroitlocker.com/DT.htm
'71 406 GMC Short Box Fleetside - Daily Driver
'79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com
'58 LT1 Chevy Short Box Step Side - Next Project
SB406 is offline   Reply With Quote
Old 04-12-2006, 08:52 PM   #23
That`s what I bought to put in my shortbed.I`ve always been a stump-puller kinda guy,but withfuel costs,I`m going higher.I want to drive it!!I hear these pull just fine.
Thread Tools
Display Modes
