Old 03-18-2006, 12:27 PM   #1
shelby987
shelby987's Avatar
b, r, g, y, bl???
I was hoping someone out there could point me in the right direction. I need to hook up a tach, and I have 5 wires, blue, red, green, yellow, and black. I am no good with wires, so if someone could walk me through it.....it would be appreciated.
Thanks!
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 03-18-2006, 12:33 PM   #2
jhow66
jhow66's Avatar
Re: b, r, g, y, bl???
What kind of tach?-Model #?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-18-2006, 12:57 PM   #3
shelby987
shelby987's Avatar
its a RAC tach, the number printed on the face of it is 63003580, thats all I know, won it online.
Old 03-18-2006, 12:59 PM   #4
cdowns
cdowns's Avatar
if it's a good aftermarket tach just google the manufacturer to getemail address or better yet call an 800number to get the info
Old 03-18-2006, 01:57 PM   #5
shelby987
shelby987's Avatar
been there, tried that.....couldn't come up with anything. I found some instructions that appear generic, but the color combo doesn't match. I pulled the cover, and the red, black, and green go together, so I assume that the red is the 12v power, the black is ground, and the green will be plugged into my dash lights. Now, I am left with a blue and yellow wire. The instructions I found said the two signal wires would be green and brown, so I am at a loss.....the instructions said to hook one to the neg. terminal on the coil, and use an inductive pickup to hook up to the coil wire lead.....but they also said this would be a special shielded wire.....and my tach has no such pickup......any ideas?
Oh, and when I pulled the cover, there are two white wires coming out of a seperate area of the back of the tach, that have tape over them.....they do not appear to have ever been connected to the original wire harness.....so I have no idea what they could/would do.
Old 03-18-2006, 04:43 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
new one by me...sounds old and outdated.
NORMAL tachs...for the last 20 years or so, have had green for the coil neg... or tach terminal on the HEI, black ground, red switched power, and white to the dash lights.
Old 03-18-2006, 04:54 PM   #7
shelby987
shelby987's Avatar
it is old, but I was going for a classic look, didn't find any 'new' tachs that had the look I was going for......ttt hopefully someone can figure these wires out for me.
Old 03-18-2006, 05:54 PM   #8
jhow66
jhow66's Avatar
Try here:
http://www.musclecartachs.com/docs/referencerac.htm
Old 03-18-2006, 06:19 PM   #9
shelby987
shelby987's Avatar
if it possible that the red, green, and black are my positive, ground, and neg. on the coil, and that the blue and yellow would be a positive and negative for the lights? The author in the link above states that sometimes the lights are white, but he has seen blue and yellow......is it possible this is a seperate circuit that requires another ground?
Old 03-18-2006, 09:31 PM   #10
jhow66
jhow66's Avatar
To see if it will work hook it this way:
1--Red to power source
2--green to negative on coil
3--black to ground
4--leave other wires off
This sounds like a tach has to have a sending unit (one from the '60's)
Old 03-18-2006, 09:36 PM   #11
OJOE
Crew Cut
OJOE's Avatar
also make sure you have it set for 4,6 or 8 cly
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 03-18-2006, 11:32 PM   #12
shelby987
shelby987's Avatar
already set to 6cyl.
Does it have to be a fused power source?
Not sure if I should piggy back off something else, or just run it to the battery.
Old 03-19-2006, 10:28 AM   #13
Longhorn Man
it has to be to a switched souurse... IGN unfused at teh fuse box. If you run it to the battery, you'll have a dead battery in the morning... or if it sits for a couple days anyways.
Thread Tools
Display Modes
