Old 03-18-2006, 10:59 PM   #1
FIVE 0
BBC in 4X truck
Brand new here and first post. Im sure its been asked several times but cant find it in old posts. Im in the middle of putting a BB in my 4X and as you all know its not just a drop swap. Whats the most popular way of doing this? Cutting into the firewall, moving tranny and transfer, or not doing it at all. I made the mistake of driving the donor rig with the 454 and now cant get it out of my mind. I would like any advise from any of you who have tried this. Thanks.
FIVE 0 is offline   Reply With Quote
Old 03-18-2006, 11:06 PM   #2
BOSS
Just here to help
BOSS's Avatar
Re: BBC in 4X truck
First Welcome to the board!!! I think you could pm Yukon Jack,he has done it and has alot of pics showing details,maybe he will chime in here.again welcome
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 03-18-2006, 11:09 PM   #3
FIVE 0
Re: BBC in 4X truck
Thanks for the welcome and info. I will PM him and see what hes got. Thanks.
Old 03-18-2006, 11:13 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Re: BBC in 4X truck
Welcome, and i just finessed the firewall where the hei rubbed, got some corvette valve covers with the brake booster notch, and a pair of 77 stock exhaust manifolds from a 1/2 ton truck. This was about 8 years ago. Went fairly smooth from what i remember.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-18-2006, 11:18 PM   #5
FIVE 0
Re: BBC in 4X truck
Thats good info. I was looking at Vette valve covers on ebay thinking that my help, being the drivers side is the closest. Im also going to run an HEI and im sure I may have to work that area over to when I get there. Thanks.
Old 03-18-2006, 11:27 PM   #6
too much stuff
Roadtrip!
Re: BBC in 4X truck
On my valve cover, i still had to grind a little off the lip where it hangs over the head and had to pull the tail light wires to the side a hair. I also had to grind a "nub" of the stock exhaust manifold to clear the cross member. I will post more as i think of it, or i can try to get some pics. I set mine on the 350 mounts. I hear a body lift makes it easier, but i don't have that.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-18-2006, 11:31 PM   #7
sakohntr
sakohntr's Avatar
Re: BBC in 4X truck
Use all the small block motor mounts and move the whole assembly forward 2 inches. If its a stick you'll have to move the clutch z-bar pivot as well.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 03-18-2006, 11:45 PM   #8
FIVE 0
Re: BBC in 4X truck
If you move the rest forward, how does the rear driveline fair? I think my front one can take it but not sure about the rear. Thanks Ror
Old 03-19-2006, 12:45 AM   #9
FIVE 0
Re: BBC in 4X truck
Just got moved here and thought I should add a little info that may help. Its a 72 3/4 4X with an auto. Thanks.
Old 03-19-2006, 06:18 AM   #10
4x4Poet
The BBC is a little longer from the center of the mm to the bellhousing mounting surface, so that should help mitagate moving the whole engine foward. Not that I'm saying that's the thing to do. I'm sure there's a site with BBC vs. SBC dimensions.
One can use a 73up crossmember so clamshell mm can be used. Try a search on 4x4 & BBC and crossmember or xmember and some BBC into 4x4 threads should come up.
If one moves the z-bar mount foward with the BBC, how does one elongate the pedal rod from clutch pedal to z-bar? Cut, sleeve, and weld?
Some one once mentioned using a '70s BBC mech clutch z-bar set up from clutch pedal rod to clutch fork, but I haven't been able to ascertain the reason why or advantage in doing so. If there truly is an advantage. Hydraulic clutch is an option with fabbing and the right bellhousing.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-19-2006, 11:27 AM   #11
FIVE 0
Re: BBC in 4X truck
Im running a TH 350 auto, hope it holds up, so I dont need to worry about the clutch linkage. I will look at other xmembers though. Thanks for the info.
Old 03-19-2006, 05:32 PM   #12
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: BBC in 4X truck
Welcome to the board and I hope the info I pm'd ya helps you with the swap. I was going to post the article on the 73-8something engine crossmember, but I must have it on my office computer. I will get it posted for you tomorrow.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-20-2006, 01:15 AM   #13
kwmech
Re: BBC in 4X truck
[QUOTE=4x4Poet]The BBC is a little longer from the center of the mm to the bellhousing mounting surface.
The measurements are identical---small block, big block, 6.2 and 6.5 diesels
Old 03-20-2006, 07:29 AM   #14
4x4Poet
Re: BBC in 4X truck
[QUOTE=kwmech]
Originally Posted by 4x4Poet
...The measurements are identical---small block, big block, 6.2 and 6.5 diesels
Coulda swore I'd seen different in engine dimension diagrams with the "A, B, C, etc. measurements," but I'm sure my memory is at fault. Thanks for the correction.
Old 03-20-2006, 11:24 AM   #15
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: BBC in 4X truck
Here is the article on the new engine crossmember link 1 link 2
Old 03-20-2006, 01:38 PM   #16
qksilver
Re: BBC in 4X truck
That article make it look so easy............
I have all the later model stuff , I will try it on the second to next project!
qksilver is offline   Reply With Quote
Old 03-20-2006, 08:03 PM   #17
FIVE 0
Re: BBC in 4X truck
Outstanding link. Just printed it out. Thanks again for the info. Ror
Old 03-21-2006, 01:10 AM   #18
454_72_4X4
454_72_4X4's Avatar
Re: BBC in 4X truck
I'd have to agree. The 73+ X-member would be the way to go. I didn't know about that when I did mine the first time so it sits on the stock 350 mounts and x-member.
I "clarenced" the firewall on both sides but didn't have any problems with the HEI. It has all kinds of room, almost 3/16 of an inch! LOL
I used the right manifold off of a mid seventies BB pickup and the left was off of a 66 BB car, (Impala I assume). The car manifold has since cracked into 3 pieces and I replaced it with an unkown manifold. I had to remove a little "slice" off of the frame and remodel the engine mount some to get the replacement manifold to fit.
BB and SB motor mount dimensions are the same so there's no worries there.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-23-2006, 06:39 AM   #19
4x4Poet
Re: BBC in 4X truck
That link to a 4x4Power mag article is the one I have that I've posted about several times. I don't have a digicam, unfortunately.
The BBC radiator shroud shown doesn't look like a 67-72 2wd BBC shroud to me. It looks like a either a 73up shroud or maybe a 2wd SBC shroud. The one in back of the BBC shroud does look like a 67-72 4x4 SBC shroud.
Thread Tools
Display Modes
