Old 07-25-2002, 08:07 PM   #1
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
removing cross shafts and control arm bushings?
ok this isnt on one of my trucks but my imapala...... so its basically the same...... i got the whole suspension stripped down and need to remove the control arm bushings to put in my new energy suspesnion pieces........... anyone got advice? thanks
68SWB4x4 is offline   Reply With Quote
Old 07-25-2002, 08:43 PM   #2
johnymac
Removing bushings
I used a cheap propane torch, then a large screw driver and worked the pieces out. Only took mintues to get out.
Good luck.
johnymac is offline   Reply With Quote
Old 07-25-2002, 09:00 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
thanks, thats what i was thinking, i need to invest in a propane torch
Old 08-12-2002, 11:15 PM   #4
HEAVY CHEVY
BOWTIE FOREVER
HEAVY CHEVY's Avatar
You can burn them out or try using a press.I used the press at work shag but your working on a 64 right??It may be different for your IMPALA than mine.If you can take your control arms down to your local garage or machine shop they should be able to do it fairly cheap.
69 C-10 SHORT FLEET BED
350 4-BOLT/400 turbo
upper & lower molding
65 IMPALA 2-DR
283/POWERGLIDE
66 IMPALA 2-DR
hopefully 283/350
~ CAMELTOE ROCKS ~
HEAVY CHEVY is offline   Reply With Quote
Old 08-13-2002, 12:26 AM   #5
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
i burned them out about a month ago, was fun.... lol
Old 08-16-2002, 07:18 PM   #6
HEAVY CHEVY
BOWTIE FOREVER
so did you get the a arms back in your 64 IMPALA?
65 IMPALA 2-DR
283/POWERGLIDE
66 IMPALA 2-DR
hopefully 283/350
~ CAMELTOE ROCKS ~
Old 08-16-2002, 09:39 PM   #7
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
nope i work slow plus ive been busy with "otherthings"
Thread Tools
Display Modes
