Old 04-04-2006, 07:17 PM   #1
HORSEDOC
Heater core removal with factory air?
First off, Thanks to all members on this board. I just completed a frame off restoration with my 16 year old son on a 71 shorty (his first truck). We started with zero mechanical ability and with the help of this board we were able to by parts,learn to weld,paint and generally fix everything.
We put her on the road today, passed state inspection with raves and lots of compliments. It felt great.
anyway on our maiden voyage the heater core blew. do I remove this from inside the cab. It has factory ac?
HORSEDOC is offline   Reply With Quote
Old 04-04-2006, 07:52 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Heater core removal with factory air?
Here's a thread from the FAQS to get you started. It's a non AC but the principle is the same.
http://67-72chevytrucks.com/vboard/s...ad.php?t=69812
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-04-2006, 08:21 PM   #3
john
member #16
john's Avatar
Im pretty sure you pull the heater core from the inside with A/C cab.
john is offline   Reply With Quote
Old 04-04-2006, 09:10 PM   #4
kaycee
kaycee's Avatar
Yes pull it from the inside you have to take off s-duct and the floor heater outlet pretty easy really.I did mine in an hr or so(malted beverages are optional)
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 04-04-2006, 10:41 PM   #5
Andy4639
Old member
Andy4639's Avatar
For A/c removal, for heater core work. Take passenger side wheel off inner fender and unbolt the nuts under the air box in the bottom of it. Disconnect heater hoses and other misc. stuff loose. I just finished this project myself. You may be able to leave the outside box on the fire wall but I wanted to check everything while I had it off. The heater core is in the passenger side coner inside the box that comes out from the cab.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-04-2006, 11:45 PM   #6
Tynee
I miss this truck.
Tynee's Avatar
I'm certain that someone will correct me if I'm wrong, but I believe that there is one screw that holds the core in that comes from the outside of the box under the hood. I remember having to drop the inner fender to access it. This only applies to the A/C trucks, though.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 04-05-2006, 05:14 AM   #7
Andy4639
Old member
Andy4639's Avatar
I had 2 screws from the cab side that had nuts on the fire wall side that aren't seen without taking the inner fender off. When you pull the box out of the cab there's nothing holding the outside box up in place except one sheet metal screw right near the fan. I wanted to resaeal mine and check for gaps around the A/C evaperator too.
Old 04-05-2006, 08:05 AM   #8
Huck
Huck's Avatar
In many cases, it probably pays to do the total job of removing both boxes if they haven't been removed before -especially if the A/C is not operational. You will have years of leaves, pine needles and probably mouse stuff inside the inner box with your blower fan chewed by Mickey and friends which will have put it out of balance. All this crud significantly reduces air flow -heater and A/C effectiveness. Best if done by removing pas side inner fender --then it will come out pretty quick. You can usually do the whole thing in a couple of hours. Biggest problem will be reinstalling the glove box cardboard which if original --will break into about a dozen pieces. Be especially aware of the importance of the two grounds--one off the blower motor and the other off the A/C fan relay mounted on the box just below the glove box.
Huck is offline   Reply With Quote
Old 04-05-2006, 08:52 AM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Wish I had been a board member years ago when I replaced my heater core... luckily (?!?), my mind has erased much of the painful memory About all I remember is it was a PITA.... I did not remove the inner fender (factory air).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-05-2006, 01:12 PM   #10
dwaite72lnghrn
I dropped the innere fender. It took 5 minutes and save alot of cussin and agravation. There is 4 sheet metal nuts on the outside and 2 on the inside.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 04-05-2006, 07:56 PM   #11
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
Boy, I wish I would've done it that way, but I'm always a tad bit dyslexic mechanically.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 04-05-2006, 11:15 PM   #12
72armyswbtruck
72armyswbtruck's Avatar
Sweet talkin about timing, I am doing this this weekend
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Thread Tools
Display Modes
