Old 04-06-2006, 01:31 PM   #1
67chevemall
67chevemall's Avatar
Fuel regulators? return line?
Howdy
When you use a fuel regulator do you have to put a return line to the
cell for the extra pressure/fuel and you are turning back.
or
Does it not matter that you build up a little pressure in the line with
the regulator??
Any ideas on fuel delivery would be great..
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-06-2006, 04:24 PM   #2
shifty
Questionable
shifty's Avatar
Re: Fuel regulators? return line?
normally a fuel pressure regulator has a return line to put excess fuel in the tank. your pump will put out X amount of fuel, which is usaually more than the regulator will need. it has to put the excess somewhere or else something is gonna bust (or your pump is gonna fry)!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-06-2006, 06:11 PM   #3
67chevemall
so the stock pump is about 6psi and I have a gauge that is reading 4...
I have a Holley regulator that has the bottom plugged, ..where does that pressure go?
Should I unplug it and run a line from the bottom outlet to the tank?
The regulator only has an arrow pointing straight through..I didn't realize the bottom is a return line..If that is what it is..as I have no idea what it is..
Old 04-06-2006, 07:29 PM   #4
ratrod67
ratrod67's Avatar
I believe there is no need for a return up to 7 psi. After that a return is needed.
ratrod67 is offline   Reply With Quote
Old 04-06-2006, 07:42 PM   #5
67chevemall
This would be easier! I could just plug the extra outlet on the fuel cell........Anybody else?
Old 04-07-2006, 12:02 AM   #6
cduster
I ran one on a stock fuel pump with no return. Didn't have any problems
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Thread Tools
Display Modes
