Old 04-06-2006, 10:56 PM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Windshield install
What is the proper procedure to install a windshield?
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-06-2006, 11:03 PM   #2
jhow66
jhow66's Avatar
Re: Windshield install
Call a windshield company and have them do it.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-06-2006, 11:16 PM   #3
Brainchild
Brainchild's Avatar
Well that is just totally out of the question for me.Cause they won't let me help
Besides the more money I can save,the more tools I can buy.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 04-06-2006, 11:19 PM   #4
matthufham
trim or no trim? trim needs to be installed into the rubber, then the rubber onto the glass, then use a wire to put the rubber lip over the windshield frame. use some lube and take it slow. almost like installing a bicycle tire.
matthufham is offline   Reply With Quote
Old 04-06-2006, 11:24 PM   #5
rage'nrat638
rage'nrat638's Avatar
piece of cake...have trim...install trim into rubber gasket.now slip windsheld into trim.install thin rope at top all the way around to the bottom from both sides. use dish soap to lube the gasket all the way around..in this grove...place into position
bottom first...have a second person push as you pull the string and you will see the inside lip popping in out side person keeps moving and pushing as you pull rope
all the way around untill complete.done
rage'nrat638 is offline   Reply With Quote
Thread Tools
Display Modes
