Old 04-12-2006, 04:27 PM   #1
fade94
fade94's Avatar
Question re: rear flip and driveshaft issues
I want to lower the rear of my 71 at least 4". Since it is a leaf spring truck, what are my options besides puttin the axel under the spring? Also, will this much drop have any consequences regarding drive shaft length?
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 04-12-2006, 06:04 PM   #2
Fmspeed
Re: Question re: rear flip and driveshaft issues
if it has over loads, remove em, then loose a few springs, the springs i have are way over kill, if u flip the axle ur gonna have to c- notch the frame to get any travel, as far as the driveshaft, i have no clue, i made my truck a 1 piece after i dropped it.
Fmspeed is offline   Reply With Quote
Old 04-12-2006, 09:41 PM   #3
corn
I flipped mine & didnt notch. Theres enough room without a notch if you dont haul heavy loads. My drive shaft is fine too. Ill snap a couple pics tonight for you, Ive got the box off right now...corn
corn is offline   Reply With Quote
Old 04-12-2006, 10:31 PM   #4
KAILUAZ
King of Rust
KAILUAZ's Avatar
What did you do to flip the axle? I have leafs also and was considering a flip, thanks.
1970 GMC 2500, 350, TH400, front disks, thats it!
My Pics
KAILUAZ is offline   Reply With Quote
Old 04-12-2006, 11:52 PM   #5
corn
I used a 73-87 kit. I did have to trim a little off the top edge where the brackets sit up into the stock perches. Other than that it was a bolt in...corn
Old 04-13-2006, 08:23 AM   #6
fade94
fade94's Avatar
My truck is not going to be used to haul anything but the kids. I looked at ECE last night and they have a 4" drop spring but it's also almost $400. I may remove some leaves first. The truck does sit WAY high in the back.
Old 04-13-2006, 06:34 PM   #7
72MARIO
72MARIO's Avatar
Corn,
Have you changed your shock angle yet ?
I have a 6" spring drop. I had 4" drop shocks for the coil applacation in they had the right travel but were on the wrong angle.
I used 1" drop shocks for the front of our trucks for the rear shocks. If you look at the existing shock mount there is the stud pressed in look to the back of the bracket there is a empty hole. I drilled it out and used a front shock stud in that hole and bolted the shock in place. Now the truck rides way better and alot smoother.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-13-2006, 07:02 PM   #8
corn
I put a set of Doetsch-Tech drop shocks on it & they seem to fit pretty good. I think the flip kit is a Western, I bought it from a board member but I think they sell new for @ $75-$100. The spring pin hole is offset to keep the driveshaft length & pinion angle correct...
Thread Tools
Display Modes
