Old 04-17-2006, 01:19 AM   #1
cell
Active Member
cell's Avatar
grease points on 73-87 front suspension?
Somewhere along the way car manufacturers started moving away from grease points and using "sealed" front end components which you didn't have to grease (in theory...).
I have heard these sealed front ends wear out faster, so I am wondering, were there any changes with regard to the number of grease points from 73 to 87, or are they all essentially the same (for 1/2 ton)? I will be doing a crossmember swap on a 67 pickup in the near future, and want all the grease points I can get!
cell is offline   Reply With Quote
Old 04-17-2006, 02:26 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: grease points on 73-87 front suspension?
If you want lots of grease points, you might try to find a 71 or 72 crossmember to swap in. They still had steel greasable control arm bushings, which add 8 more zerks over the 73-87 rubber bushing style.
Old 04-18-2006, 12:10 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Tx-
I thought that some of the trucks from 73-79 (?) had greaseble control arm bushings in some of the catalogs I came across. Maybe, it was for illustration purposes only. I don't remember if the 73 has the greaseable bushings.
Cell-
The 83 has rubber control arm bushings, but all other parts have zerk fittings. To reduce road vibration/noise, the rubber bushings version are probably an improvement over the metal bushings version.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-19-2006, 06:12 AM   #4
Tx Firefighter
Boxrodz, you do have a point. I know 3/4 and 1 ton trucks still used the steel greasable bushings for many more years. I believe through the late 80's
Thread Tools
Display Modes
