fuel gauge fuse????????
So I was lookin at the reason behind my gas gauge being pegged at the 3oclock position. I then saw the fuse marked fuel gauge is missing. Its got two male ends in the fuse block so its one of those femail U shaped fuses, I tried lookin up the size in my chiltons, but it didnt specify it.
Does anyone know what that fuse amperage would be 69 c10 250 I-6 if it matters
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
its all about the +6 inches
Re: fuel gauge fuse????????
That male terminal you see is a plug.
![]() There should be a tan/brown wire going from the fuel tank's sending unit, to that wire. If you are missing that wire all together, (slide seat forward and look at the sender) PM me, i got a wire here complete with plug for 5 bucks shipped. |
ok i foudn the wire, it has a single plug on it, does it plug into the top or bottom blade in the fuse block, or is that the wrong connector, the wire does run from the fuel sending unit
#4 | |||
Union Electrician
From the looks of the pic it should go in the top one as the red line is pointing to it.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#5 | |
yeah as soon as I posted that I saw the arrow, forgive me 7 straight 13 hr work days plays havoc on a man
#6 | |||
Union Electrician
I know the feeling,I've worked many shutdowns at Ford, and Toyota plants here in Ky and most are 7-18 days long and 12-14 hrs a day.6-8 times a year and the best part is the money,but I hate putting in that much time
That is the correct location, the one beside it is for the clearance lights, it turns on with the parking lamps.
it worked, im finding lots of things that make you go hmmmmmmm as to why the previous owner did it
#9 | |
Hey ANDY, Still got that wire availible for the fuel hook up? Respectfully
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
Sure man, toss a fiver in with the pics, and I'll get it out to you.
Thread Tools | |
Display Modes | |
