Old 04-24-2006, 02:58 PM   #1
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
rear bag set up to lay frame?
can anyone suggest or post pics of the rear set up with trailing arms with bags to lay frame can you use the stock spring location for the bag and get clearence how are the bags mounted cups?? any suggestions thanks
gostranger is offline   Reply With Quote
Old 04-24-2006, 09:33 PM   #2
project76
project76's Avatar
Re: rear bag set up to lay frame?
You are not gonna lay frame with bags in the stock coil spring location. My setup is slam specialties RE7 bags mounted off the rear with a kit i bought from suicide doors. The brackets weld to the bottom of the axle tubes and my notch is from kp components. With my truck aired out and bottomed out in the notch on 27" tires, i am still not laying frame. I just installed a drop crossmember from ECE and it atually raised my truck up almost 3" . If i had to do it all over again, i would build my own notch and 4 link the thing.
Brandon
project 67 swb bagged on 20" Coddingtons
project76 is offline   Reply With Quote
Old 04-25-2006, 12:18 PM   #3
fastbagged68
fastbagged68's Avatar
Lays frame....bag in stock location. Slam RE 72.... top mount is part of my c-notch.
fastbagged68 is offline   Reply With Quote
Old 04-25-2006, 01:47 PM   #4
hotrodhomi
hotrodhomi's Avatar
is that burb on the road yet?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-25-2006, 02:44 PM   #5
smbrouss70
smbrouss70's Avatar
fastbagged, do you have any pics of your notch?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-25-2006, 02:49 PM   #6
fastbagged68
Yes it is on the road....I have a few things i need to fix. But I am driving it!!!
I do have pix of the notch but not on my work computer. I will post them ASAP.
Old 04-25-2006, 07:31 PM   #7
project76
project76's Avatar
i stand corrected, that must be a huge notch. I love the stance
Brandon
Old 04-26-2006, 06:35 AM   #8
gostranger
gostranger's Avatar
that suburban is sick!!! i wanted one more than my truck but couldnt find a decent one anyway if you had any pics of the rear set up that would help me alot if i can i was planning on using the stock spring location for the bags and a watts link i have 20'' wheels i bought for the truck i think they are under 27'' they have super low profile tires i guess i am going to have to get some pics of the truck and put them on here for everyone to see any help or suggestions would be a great help thanks!!
Old 05-08-2006, 10:49 PM   #9
laidout69
laidout69's Avatar
my bags are mounted in the stock location and it lays frame! with slams!
1969 chevy
bagged, fully shaved still UnDeRcOnStRuCtIoN
laidout69 is offline   Reply With Quote
Old 05-09-2006, 05:56 AM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Interested. Tell us more...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-09-2006, 09:42 AM   #11
LS1powered67
LS1powered67's Avatar
I'm also interested, post up a pic I'm sure there are a few others that would like to see. -steve
1967 C10, Short & Wide with LS1 & T56.
LS1powered67 is offline   Reply With Quote
Old 05-09-2006, 10:01 AM   #12
Leks
I would use a cantilever/4link setup. Pricey but I would have it no other way!
http://www.adicustoms.com/
Leks is offline   Reply With Quote
Old 05-12-2006, 02:08 AM   #13
bskylerj
bskylerj's Avatar
Can you tell us more on this? What about some pics?????????????
Did you cut the bed?????
bskylerj is offline   Reply With Quote
Old 05-12-2006, 06:23 AM   #14
gostranger
gostranger's Avatar
does any one have some pics this would be a great help thanks
Old 05-13-2006, 11:58 PM   #15
bigbuc
Certified Pud Puller
bigbuc's Avatar
heres my 4 link
1997 Silverado extended cab- mpfi conversion, 22" kmc's
1983 C10- some assembly required
99.5 F250 Super Duty 7.3 5" straight pipe, wicked wheel, ts tuner, ccv mod, 4" lift 315/75/16s
bigbuc is offline   Reply With Quote
Old 05-14-2006, 02:35 AM   #16
hotrodhomi
hotrodhomi's Avatar
^^^I wouldn't leave your bags plumbed like that. When you connect the two sides you allow air to go from one side to the other when you turn. This is very bad for your handling.
'66 impala ht
Old 05-14-2006, 06:51 PM   #17
bigbuc
bigbuc's Avatar
thats just my little rig to get it off the floor so i can move it in and out of the garage i have all my 1/2 dot lines but im waiting for the fittings...
Thread Tools
Display Modes
