Old 04-25-2006, 10:31 AM   #1
jpkerley
Active Member
stripping my truck
i plan on changing the color of my truck, what is the cheapest easiest way to strip it and what can i spray it with to keep it from rusting until i can get it painted Thanks. Its going to be a daily driver and I have good cheap help.
jpkerley is offline   Reply With Quote
Old 04-25-2006, 10:40 AM   #2
redhead69
fugedaboutit
redhead69's Avatar
Re: stripping my truck
If you own a compressor I would use a DA sander. Do you need to take it down to bare metal? If so I would use a self etching primer first, then a sandable sealer/primer of some sort. Theres alot of variables here and you might be better off in the Paint/body forum..
Currently truckless
redhead69 is offline   Reply With Quote
Old 04-25-2006, 11:22 AM   #3
shifty
Questionable
shifty's Avatar
there are also dipping options, keep something mind:
cheapest is rarely ever easiest. you could spend no money, but spend several days sanding with a DA or using a paint stripper to remove the paint...or you could spend a little cash and a fraction of the time with a sandblaster (make sure you ask for tips on this first)...or you could spend no time at all and a few more bucks than a sandblaster and have the thing soda dipped or acid dipped, then dipped in a zinc bath of some sort (or whatever). i think those are the three big options.
you may want to post this topic (or a mod might move it) over in the auto body forum. Take a quick gander at the entire forums list - there are a lot of sub-forums that are not specific to our year of trucks.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-25-2006, 11:47 AM   #4
Coleman
Coleman's Avatar
My $.02 worth. I'm stripping one of my projects now. I started sandblasting and found it just too messy. I'm now using a "Full Cable Twist Wire Wheel" that fits on my angle grinder. The thing strips the paint right down to the bare metal in no time. The wheel costs ~14 at lowes, you might want to give it a try before you move onto other options. Its seems to be working for me.
68 Chevy K20
72 Chevy K20 (new)
2000 Silverado Z71
Coleman is offline   Reply With Quote
Old 04-25-2006, 12:01 PM   #5
shifty
Questionable
shifty's Avatar
they have these things called "flapwheels" that work really well for stripping large body panels fast. it looks like a turbine, but the fingers are pieces of sandpaper. very handy for clearing all kinds of stuff.
Old 04-25-2006, 12:04 PM   #6
weasle
weasle's Avatar
That Full Cable Twist Wire Wheel looks real abrassive. It didn't mess your sheetmetal up any?
weasle is offline   Reply With Quote
Old 04-25-2006, 12:39 PM   #7
jimmydean
jimmydean's Avatar
There was an infomecial a while back for the paint stripper that was like a flap wheel only it used metal bars about 18 gauge or so. It looked cheesy, but it worked well. It went on a drill and took pain off without leaving marks in the metal.
Might be able to find one online at "as seen on tv" or something.
jimmydean is offline   Reply With Quote
Old 04-25-2006, 01:54 PM   #8
shortymac83
hmm...
shortymac83's Avatar
I've used chemical stripper before with good results, but I wouldn't use it on body panels where it can get trapped inside and screw up your new paint job. Fenders, header panels and hoods work well with it.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 04-25-2006, 02:09 PM   #9
wolfthing2000
Whatever you do don't even think SAND BLAST! All that is is a zillion little hammers pounding and stretching the metal= BIG DISASTER!!!!
Obviously, unless the truck is completely dismantled, you won't be acid dipping.
Chemical and a thing callsed the stripper or sandblaster or something of that sort at lowes. Like a dis sander to fit on your angle grinder . It looks kinda like a hard sponge, purple colored. Works great. Mine required some kinda quick change mounting feature, but i modified it and rin it just like a disc sander.
Works better than anything I have ever tried!
wolfthing2000 is offline   Reply With Quote
Old 04-25-2006, 02:29 PM   #10
paintpyro
paintpyro's Avatar
Im using a Craftsman 7 inch sander/polisher w/80 grit sanding disks. I feather the throttle as not to grind too much, and will coat everything with an epoxy primer after.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 04-25-2006, 08:47 PM   #11
ohmsc10
ohmsc10's Avatar
I use discs that look like 3M scotchbrite pads. You can get 4" discs at lowes called SANDBLASTER. They come in sets of 3. Work very well on a grinder.
ohmsc10 is offline   Reply With Quote
Old 04-25-2006, 09:55 PM   #12
Billla
Billla's Avatar
I've had many, many cars and parts media blasted with great results. I agree that getting a commercial sandblaster and just going for it is going to destroy anything...but plastic media, properly applied, leaves a beautiful finish and does a great job of cleaning stuff.
Billla is offline   Reply With Quote
Old 04-25-2006, 09:58 PM   #13
cstanley
cstanley's Avatar
any swirling problems with the disks?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 04-25-2006, 11:01 PM   #14
CoolRide
CoolRide's Avatar
I JUST stripped my 67 and I used "flapper discs" from Wal-mart I used about five of them, worked real good. Put them on my 4 & 1/2" angle grinder.
Took about 15 hours probably. I have a sandblaster but I knew this would be quicker and cleaner, and cheaper.
CR
CoolRide is offline   Reply With Quote
Old 04-26-2006, 01:18 AM   #15
kevncar
Active Member
kevncar's Avatar
I've been using the "Sandblaster" wheel sold at lowe's that wolfthing2000 mentioned. I've only used it on my frame and some other misc susp. parts. But it works good and I have heard some people say they think they could do a whole vehicle with one. I think it might be possible.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 04-27-2006, 02:23 AM   #16
hogrocket
Junior Member
I just got my 70 K20 back from the sandblasters. It was a commercial outfit with 30 years plus experience. They charged 800.00 to sandblast the whole thing to bare metal (including the bed and door jams) and primer it. I stripped all the trim, bumpers and lights off and they did the masking. It came out great. The key to not warping the metal is pressure adjustment and experience. I don't think I woild try it with some of the newer models (thinner metal). After I finish the paint I will submit some before and after pics. Matt
hogrocket is offline   Reply With Quote
Thread Tools
Display Modes
